Scenic kaartpakket status probleem
Quote from ZeroCafeine on 15.05.2023, 05:37Hi, a problem. Scenic crashed for unknown reason. So I removed the app and installed it again and logged in.
However, now I have no map displayed. And getting the offline maps associated with my account I get an error
"kon de status van het kaartpakket niet ophalen" and there it gets stuck in "laden kaartinformatie"
I did spend some credits on the maps. Thought perhaps it's because I have zero credits left, so I purchased again a small amount but to no avail.
Same behaviour on my iPad.
Is there a problem at the moment, or is it associated with my account?
Quote from Guido on 15.05.2023, 06:23Could you have a look here for common causes for maps not downloading: https://scenic.app/help/map-update-stuck-not-loading/
Btw, if you are logged in with your Scenic account, Scenic will know the regions you purchased before and you won’t get charged credits again for those regions. So, after a redownload, make sure you login to Scenic.
Quote from ZeroCafeine on 15.05.2023, 10:46I turned the vpn off and it's back in business. And the purchased regions I got back too. Thnx!
Quote from Guido on 15.05.2023, 10:54Just out of curiosity... what VPN do you have? NordVPN by any chance?
Quote from ZeroCafeine on 15.05.2023, 11:30Yes NordVPN. The region was set to Netherlands so I didn’t think this would be the problem. Maybe it caused to unexpected close of scenic too while touring. I will have it off from now on if using scenic.
Quote from Guido on 15.05.2023, 11:34I don't think so. NordVPN has been causing problems with HERE map download for as long as I know. Somehow, for some reason, NordVPN is blocking the servers where HERE is hosting their map files. I'll take this up with HERE. They need to either change some configuration of their map servers and/or contact NordVPN about it.
If you're up for it... could you download the HERE WeGo app (that's HERE's own app) and check if that works through NordVPN?
Quote from ZeroCafeine on 15.05.2023, 12:49oké, I tested HERE WeGo. That works and also downloading the offline maps works for NL/BE
Scenic worked without vpn and had displayed the map + downloads correct.
closed scenic, turned on vpn, started scenic but now I got a map displayed incomplete.
closed scenic, turned off vpn, started scenic and everything is fine again
Good I would think the case is clear. VPN is the cause. But then suddenly scenic works correct with the vpn on, and again?
I can't get consistent behaviour for scenic to fail with the vpn on.
If the map is displayed correct in scenic with the vpn on, I can access the offline maps to download. But the download process doesn't seem to start.
Downloading another file on my phone from the internet is quick though. and going to back the Here WeGo app, the download off a map works, while scenic is still stuck in downloading.
I can't figure it out. VPN off is the best atm.
Quote from Guido on 15.05.2023, 12:58I can explain part of this: Once you have the offline maps installed, Scenic doesn't require a connection to the map server anymore. It will work based on the offline maps that are on the device.
Also, if Scenic does not have offline maps installed, it downloads map data on the fly and stores that in its cache. The cache some limited harddisk space that store recent map data. If the cache is full and you look at a new map area, it throws away the oldest data in the cache to make room for the new data.
So, on the first try, probably some data was downloaded to the cache. On the 2nd startup (with VPN) it used the cache to display the map.
Quote from ZeroCafeine on 15.05.2023, 13:36yes the cache was something I thought about a bit. Because at first the map displayed wrong was very shallow, later it became bigger but still wrong with he vpn on But not in my area. To make sure the downloaded maps didn't interfere I had removed them.
Summary scenic; with he vpn on, the map displayed is not correct although it could be correct nearby or at area's where was zoomed in (without vpn), as it is in the cache. (with closing & restart). And with vpn, the downloads do not work but could be initiated or get a failure mentioned in post #1. But that error I haven't encountered anymore.
With Here WeGo, with the vpn on, downloading maps work and when the offline maps are not downloaded, you still can zoom everywhere and get every detail
So there's a bit of consistency after all!
