Map downloads not happening
Quote from Not Lost On Me on 20.12.2022, 10:21After creating a route, I receive a message suggesting I need to download the desired map region otherwise, "the route might take main roads only". I request the download, select the map area, and I am told it will "cost" 6 points, which I agree to. Apparently, I am supposed to see the download progress in "Downloaded-Purchased" section however it does not appear. The "Downloaded-Purchased" area indicates the count as "0/1". Also in that area I do see another prompt that says "Tap to download" (with a downward facing arrow) however when I select this, I receive a quick flash of a message in red that says "Stop Map Downloads". Unfortunately the map never seems to download even though it appears that my points have been taken. The map is 365MB in size. I have high speed internet and a map of this size should be a quick download. Any suggestions?
Quote from Guido on 20.12.2022, 10:31Have a look here for common causes and solutions as to why this ought happen: https://scenic.app/help/map-update-stuck-not-loading/
If that doesn’t help, please let me know.
Quote from Not Lost On Me on 20.12.2022, 10:42Hi Guido. I reviewed the comments in the link. I am not using any VPN on my iPad. I will note that my iPad is old (iPad Air OS 12.5.6) and I am also using an older (compatible) version Scenic (can't seem to fine the Scenic version anywhere).
Quote from Guido on 20.12.2022, 12:15Hmm. In that case I need to check when I’m at my computer later today/tomorrow. The old version of Scenic uses an old map provider that stopped their service. At some point in time they will stop giving map updates. Perhaps that moment arrived but I can’t check now.
Unfortunately the new version of Scenic only runs on ios14 and up, so you cant run that on older iPads.
I’ll report back to here tomorrow with my findings.
best regards,
guido
best regards,
guido
Quote from Not Lost On Me on 28.12.2022, 17:37Hi Guido - do you have any further thoughts on maps not downloading?
The app did take my points (twice I believe) even though I was not able to download the maps
Quote from Guido on 29.12.2022, 22:23I’m so sorry for my late reply. This fell through the cracks. I need my old iPhone to test this for myself. I will do this first thing tomorrow and get back to you here.
Quote from Guido on 30.12.2022, 11:13Ok. Did some investigation. What’s happening is that most of the map servers have been decommissioned. A few are still working though.
Scenic has a function that chooses a map server to download from at random (To distribute the load on the servers).
As a workaround, what you can do, is continue to tap the download button of a map until the map starts downloading. On my tries it took between 10 and 20 taps before it found a working server and the map started downloading. Your results may vary, but eventually it should start.
I realize this is not ideal, but I hope this is workable for you.
Quote from Not Lost On Me on 01.01.2023, 14:35Guido - thanks so much for investigating this for me.
Your suggestion worked. I had to tap the download button numerous times until the download started.
My "Offline maps on device" indicated "1" however after I logged out, and logged in again, the map was no longer on the iPad. I had to download it again.
Is that normal?
Is that normal?
Quote from Guido on 01.01.2023, 15:00Yes. That is normal. Offline maps are linked to your account, so when you logout the maps are removed. When you login again you’ll have to redownload (but Scenic knows you already paid for it so you don’t have to pay again)
Quote from Not Lost On Me on 01.01.2023, 15:10thanks again for the explanation
is there a means to send you a private message?
Quote from Guido on 01.01.2023, 15:45Yes. There is an ‘email me’ button at the bottom of the support page https://scenic.app/help/
(Not putting my email in plain text because web crawlers might pick it up)
Quote from Anton Skomager on 26.01.2023, 13:58I tried to update map info on my iPhone, no problems, but my iPad cannot download. Deleted Scenic, reinstalled and now I cannot download offline maps. When I try “settings” it crashes. iPad pro iPados 16.3.
Useless right now on my iPad
Quote from Guido on 26.01.2023, 14:02Hmmm... could you try:
- removing Scenic again on your iPad.
- Then reinstall through App Store.
- Login with your Scenic username and pw
- When you download maps, make sure you are not using a VPN. Some VPN's down work with the map provider of HERE maps (NordVPN and Surfshark I know of, but there might be more)
Not sure why Settings is crashing for you, but let me know if that's still the case after these steps.
Quote from Anton Skomager on 26.01.2023, 15:35Hi Guido
Tried 3 times. Does not help. Cannot even download Andora.No vpn, tryed with 4G, wifi, no change.Settings still crashing…What to do?
Hi Guido
Quote from Guido on 26.01.2023, 15:52I’m now getting more reports about map updates / map downloads not working. It’s probably the map server of HERE that is overloaded. Probably better to try tomorrow.
Settings not working might be a problem with your account. Do you also see a blank screen when you tap on your profile picture in the side menu?
what is your Scenic nickname? Then I’ll have a look.
Quote from Anton Skomager on 27.01.2023, 02:25Anton Skomager.It seems that downloading maps is working again. Still crashing with settings on iPad, not iPhone- No problem with the picture.
