Why does scenic not follow a planned route?
I have ridden this route several times and every time scenic Ross me to stand on I 17 below the indicated exit. Is there a setting I need to be aware of? No I do not go off route so it is not a detour.
https://scenicapp.space/route/mJykkpLb
Sorry, I just noticed my typos.  So, every time Scenic has re-routed  to continue south on I-17  below the planned exit.
Do you mean the exit before via point 8?
Do you have auto-skip via points turned on? (Settings > Navigation & Tracking > Detour behaviour). If so, this could be the reason. Perhaps Scenic thinks you went off route a few times, triggering an auto-skip, removing via point 8. When via 8 is removed it will take the next exit to go to Via 9 (which became via 8 in the screenshot below).
Even if you did not deviate from the route, GPS inaccuracies, or inaccuracies in the map data could cause a recalculation as well. To decrease the chance of a "phantom" recalculation you could increase the threshold distance in Settings > Finetuning > Route recalculation parameters.
Alternatively you could turn off auto-skip, or increase the number of recalculations required to auto-skip. More info here: https://scenic.app/help/detour-behaviour-scenic/
Thanks Guido. I turned auto Skip off. I appreciate the advice!
