Forum breadcrumbs - You are here:Scenic ForumUsing ScenicWhere is my track?
Where is my track?
on 22.10.26 I recorded a track on a trip and saved it after reaching my target. But I can't find this track in "My Rides", what happened? Can you see if this track is still on your servers or is it gone?
Marc-Antón
Entering My Recorded Rides, you find a search field at the top of the page. If you didn´t rename the route when saved, you can search "2026-10-22" and it should show. If you renamed the ride, enter one of the words used. And the ride should pop up as a search result
Johan
Thanks for your help and yes, I know this, and I did this search, but the track wasn't found, and did not popup in the search results.
Additionally I searched all folders manually but it's gone.
Make a test. Save a new trip, only a short one should do. See if you find it. If you do, then you probably did not save the one you are missing.
Johan
I am sure that I saved this trip!
OK.
But I would still make that test. Just to see what happens.
It happened on a trip and I saved four more tracks on that trip, they are all available, only the first one I saved is gone.
And I'm absolutely sure that I saved the first track, when I arrived my destination!
Shit happens of course. I have pressed the wrong button a couple of times. And I guess that’s my best answer..
On the server, on 22 October, I see a ride 'Fahrt Norbert 22.10.26' in the folder 'Männertour 2026'. Account nickname RiaRio, that's you right? @massi.
Yes, thats right. I made this second account, when I was banned from my first account.
I had searched all folders manually and didn't find it, seems that  I had tomatos on my eyes.:-}
Happy you found it!
Yes, me too, thanks for leading me to the right direction.
