Water bodies not showing anymore
Quote from Smylight on 15.10.2026, 18:57Hi Guido,
Surprise today : lakes, rivers and all such water bodies are not showing up anymore. In fact, they first appear and then quickly go away after a split-second. I'm in Québec and here water is everywhere around us so maps are quite disconcerting to say the least. Even mighty St.Lawrence is nowhere to be seen.
Quote from Guido on 15.10.2026, 20:31Strange. Can you provide:
1) Sone screenshots with example
2) Is it zoon level related?
3) Scenic version (bottom if settings)
4) Which map style? If a custom map, can you share the map style ID? ( https://scenic.app/forum/topic/scenic-4-custom-map-styles/#postid-12240 )
Quote from Smylight on 15.10.2026, 20:43Aaaahhh… this has been a short-lived bug I believe, as everything has gone back to normal some 30 minutes ago. I had the same issue for a bit of time on both my iPad and iPhone. And now everything is fine.
Thanks for being so responsive!
