Visibility of new maps while riding
The big factor for me to choose Scenic 2 over it's competitors was the high contrast view of the maps which made it easy to see in the daylight (and night) when mounted to the bike. I was excited about Scenic 3 and now regret upgrading since I can no longer easily see the map on my iphone. I found myself bending down, squinting, and taking more time than usual trying to see the map nearly causing an accident. Please make the maps easier to see when in use. Until then, Scenic 3 is a safety issue for me. Other than map visibility, I found Scenic to be the best in its class.
Ledo
oldNNtheway, Kam and PeBe have reacted to this post.
oldNNthewayKamPeBe
I understand your point. And you are not the first one mentioning this.
Currently Scenic 3 only contains the ‘out of the box’ map styles from the new map provider.
Additional map styles will be added very soon. Later, a functionality to create your own personalized custom style will be added as well.
DervMan, Richin501 and 3 other users have reacted to this post.
DervManRichin501oldNNthewayKamPeBe
Have been using the dark maps during day for that purpose. Higher contrast that works for me. Maybe give that a try until custom colors arrive...
I noticed the same issue.  Sun is low in sky in the north this time of year, so got away with it, but need better contrast for summer.   Current scenic 3 contrast does not cut it. Will try to use dark map next opportunity, and look forward to update to get back to the future.
Thanks to OP. Exactly my reason for using v2. Will not “downgrade” to v3.
Just checking when the new map styles may be expected? Thanks!
Working on it. After new year.
TimeStandStill and PeBe have reacted to this post.
TimeStandStillPeBe
I concur with Ledo's original post.  The contrast and overall Map visibility was much easier on my eyes in previous Scenic version ( 2.0) .  I have a hard time Recording a ride while trying to view white roads and white background.  Moreover, I wish Scenic would either increase the size of road names, width of roads, and make the directional navigation icon bigger.  A pointed Arrow icon would be great.
In general I like the look and feel of previous Scenic maps.  Hard to articulate unless I had a side by side compression.  Unfortunately I upgraded to version 3.0.  I some ways, I wish Scenic would have a sweeping navigation route that looks wide like Zumo.  You can quickly glance navigation device and see which way to turn or next turn is coming up.
Having something like accessibility feature for those of us who have hard time seeing would be great.  I wear readers built into my sunglasses / glasses.  I can see my Garmin and my KTM 890 Adventure TFT screen.  I was hoping the new version of Scenic would have the same contrast and Text size feature.   We're not all 20 something anymore.
In the meantime, I'll play around with the nighttime mode.  Ultimately if I cannot see the Scenic screen and maps adequately, I probably won't use it as much.
Working on it. After New Year
KamPeBe
When can we expect the update?
Mid Feb
Scenic is still my favourite navigation app and now with the ability to adjust colours to my preference to aid in viewing while riding is a big plus.
Now that I've put you on a pedestal Guido, what is your favourite set up for best contrast?   Better yet, I suggest you put Guido's Map Set up as an optional pick.
brian
Paul_Guertin has reacted to this post.
Paul_Guertin
Quote from Candubrain on 25.04.2022, 18:40
Love this suggestion!
Is Guido's Maps Set come with latest Scenic?  Or do you have to download it and if so can you post link?
I assume Guido's Map Set is a customized look?
No there are no pre-styled custom map styles. I believe what’s meant with “Guido’s Map Set” are just the ability to create your custom maps.
In this forum topic a few users have shared some styles though: https://scenic.app/forum/topic/custom-map-styles/
Kam has reacted to this post.
Kam
Darn......here I was hoping you (Guido) would do all the work and lazy me would only have to click on your personal custom map style....lol
Quote from Candubrain on 03.05.2022, 10:45
What fun would that be? 🤪
