version 4.11 on Ipad Pro Crashing
Quote from Voglerb on 12.02.2025, 08:23I have an ipad Pro running ipadOS 16.7.10. When i try doing a search on the 'Plan' option or just a search the program crashes. If i select a location from my recent searches it will locate them. I've tried re installing Scenic....I've logged out and back into my icloud account and i've checked for updates. All other functions seem to be operating fine.
I do have the maps i'm wanting to use downloaded
There are no pending updates for my ipad. Is the OS 16.7.10 not able to run Scenic?
Quote from Guido on 12.02.2025, 11:11I just tried with my old iPad running iOS16.4, and it did not crash for me.
There is an update available (v4.12) that will run on your iPad (on any device running iOS16.4 or higher). Go direct to the Scenic app store page to update: https://apps.apple.com/app/id1089668246I did not change anything regarding this for v4.12, but it's worth a shot.
Quote from Voglerb on 12.02.2025, 17:03i tried the v4.12 but get the same result.
as soon as i type in a new search I get the searching wheel for less than a second and then it crashes out of the program
Quote from Guido on 12.02.2025, 17:08I found your crash reports... I actually already found the cause and a fix. Will be fixed in v4.13.
The crash is caused by Scenic not having received a location yet before searching. Does Scenic have location access on your iPad?
Quote from ljr on 05.07.2025, 08:28Hi Guido,
My IPAD Pro is also crashing when I startup Scenic. I did check the LOCATION SERVICES and do not see Scenic listed. I also don’t see anything in the Scenic APP settings regarding LOCATION SERVICES. Can you kindly review?
Please let me know if you need any additional information.
Thanks,
Larry
Thanks,
Larry
Quote from Guido on 05.07.2025, 09:26What iOS version are you running? It the iPadOS26 beta, this is a known issue that I’ve not yet resolved. Typically this is due to early iOS beta versions and will be resolved with next version of iOS betas
