Unable to connect to Scenic Server. Turn WiFi off and it works on cellular
Unable to connect to Scenic Server. I can connect to every app or site prior. It's probably a setting on router that is 1 week old. I am thinking that anyway. I don't want to waste time with this as it could be a lot of reasons. Feedback from router protection is it is reporting problems from this app only. app. I have had the app for 9 years and never had an issue before.
Anyone else have this problem? what did you do to remedy it?
Note: If I turn my wifi off I can connect so its not the app itself.
Firewall turned off. protection on router. reinstalled app. No help.
Are you using a VPN or security software by any chance? If so, try to disable that or add https://scenicapp.space to the "allow" list there.
If that doesn't help, try turning off your WiFi (use cellular data).
For context: a third-party security blacklist flagged our server a few weeks ago as a false-positive. VPNs, security tools, and some internet providers use that blacklist to filter traffic, which means they can block access to Scenic even though our server is operating normally.
We've already reported the false-positive and took measures and we are no longer on the blacklist. However, this can take time to propagate across all the services that use that blacklist.
My apologies for the inconvenience and best regards,
Old Man Emu
I had the same problem a few months ago. It worked fine on 5G but not over Wi-Fi. I was able to resolve it locally; in my TP-Link Wi-Fi router's app, I saw that Scenic was being blocked by the firewall. I approved access within the app, which restored Wi-Fi connectivity.
