Supporting Scenic’s Transition to OpenStreetMap (OSM)
Quote from Paul_Guertin on 13.12.2024, 13:25As a long-time user of the Scenic app, and after reading about Guido’s nightmare with HERE maps, I fully support its transition to OpenStreetMap (OSM) for mapping.
However, as OSM is community-driven, its accuracy and currency depend on contributions from users like us. After Scenic’s switch to OSM, I noticed several inaccuracies in my hometown, including outdated business names, missing buildings, and incomplete road information like speed limits.
To address this, I’ve registered as an OSM contributor and started making updates in my region. So far, I’ve:
•Renamed and updated numerous businesses to reflect current information.
•Added missing businesses, buildings and structures.
•Updated speed limits for roads where they were missing.
Contributing to OSM is surprisingly straightforward, and it’s rewarding to know that my edits directly improve Scenic’s mapping and navigation experience for myself and others.
That said, my observations about the inaccuracies in my hometown lead me to believe that, while I’d feel fairly comfortable relying on OSM data for navigation, I’d likely double-check information about accommodations, restaurants, businesses, etc., using a commercial mapping product like Apple Maps or Google Maps while route planning.
If you’ve noticed inaccuracies in your area, I encourage you to join the OSM community. Your local knowledge can make a big difference! Together, we can ensure that Scenic’s maps remain accurate and up to date for all users.
If anyone has questions about getting started with OSM editing, feel free to ask—I’d be happy to share what I’ve learned.
Quote from Guido on 13.12.2024, 14:30Thank you Paul. I really appreciate this. For what it’s worth, here is a help article for others to get started with this. It’s pretty basic so indeed if there are any questions, perhaps this forum topic is a good place to post those questions.
https://scenic.app/help/reporting-map-errors/
Quote from johansw on 13.12.2024, 14:38I did register as well 🙂
However, my/our changes has to be approved by a "local" appointed operator, right?
If yes, there is a delay / uncertanty there, I guess. But still waaay better than Here maps, where noting at all happened.
Johan
Johan
Quote from Paul_Guertin on 13.12.2024, 14:53Quote from johansw on 13.12.2024, 14:38However, my/our changes has to be approved by a "local" appointed operator, right?
Hi Johan
I don’t know if different areas have different requirements for approvals. I know that where I am located, I can make changes and upload therm immediately to OSM. My edits are typically visible in OSM within minutes. They then show up in Scenic and other apps that use OSM, such as Organic Maps as an example, whenever those apps fetch the latest data from OSM, typically every 1-2 months as noted at the end of link from Guido’s post above.
The reason I wanted to make my post was primarily to make everyone aware that, as a non-commercial product, there can be a lot of inaccuracies especially in relation to businesses, hotels, restaurants, etc. Given my experience with looking around my own hometown in OSM and finding a LOT of outdated information, I would be hesitant to rely on OSM, in this regard, for areas I know nothing about. For example, I found restaurants and motels showing in Scenic (on OSM) that have been closed for over 5 years.
Paul
Hi Johan
Paul
Quote from johansw on 13.12.2024, 15:33Thanks! I did not register any changes to the map, I just registered as a user and went through the totorial. I read about the supervisor and thought, fine, that should stop those making nonsense for some reason or other. And maybe, or obviously, there is an alternative for direct implementation. That´s fine, I guess 🙂
Your tip about inaccuracy in relation to busnisses etc is most welcome! Not nice going to a hotel, not there, although personally I mostly use Booking.com and Google maps for this type of search.
Johan
Johan
Quote from Karlchen on 14.12.2024, 03:42Hallo zusammen,
Ich habe mich angemeldet und erste Änderungen bei falschen Geschwindigkeiten vorgenommen und gemeldet.
Besten Dank für die Idee.
Ich finde auch Open Street Maps besser als Here.Schön, dass hier so viel Geld haben wollte und Guido nicht gesagt hat.🙏
Liebe Grüße
Karlchen
Hallo zusammen,
Liebe Grüße
Karlchen
Quote from rschenkels on 14.12.2024, 04:41Hi,
For what it is worth: I made a map correction on OSM in Belgium (reviewed by some local approvers), and after 6 weeks that update was available in Scenic.
Ronny
Ronny
Quote from Karlchen on 14.12.2024, 04:47Ich habe heute Morgen einmal selbst eine Geschwindigkeit geändert die laut Änderung schon drin sein soll. Und ich habe eine andere Geschwindigkeit gemeldet, worauf ich ca. 2 Stunden später eine Meldung mit erledigt bekommen habe.
Das die jetzt nicht in Scenic sein kann ist mir klar, denke aber mit dem nächsten Update sollte es so sein.
