Start Route without having to Save
Quote from colinleemoto on 01.09.2023, 13:40When using the power planner, it would be great if I could click a button to start routing WITHOUT having to save the route first. I don't always want to save a route, but I do often find it counter-intuitive that there is no 'Start' button available in the power planner.
Quote from Guido on 01.09.2023, 14:50I like your suggestion. I will add it to the list.
Meanwhile, you can create (simple) routes right in the start screen. By searching, or tapping and holding the map you can add destination and additional stops. Doesn't work as nice as the power planner, but for a route with a few stops it's quick, and the route isn't saved.
Quote from colinleemoto on 01.09.2023, 15:51Excellent! Thank you!
Quote from Lizou on 21.09.2023, 02:25I would like to support this request.
First time I used PowerPlanner, I felt at a total loss not being able to start the navigation. Took me a little while to figure out that I had to save the route first, then access it from the routes folder.Congratulations on a excellent app, otherwise! PowerPlanner is an awesome functionnality!
