Skipping Vias
Quote from Mark on 26.09.2022, 20:53Hi Guido,
Scenic has been skipping waypoints on me and rerouting seemingly on its own accord - see two example screenshots. This happened to me a lot trying to follow a BDR last week, but I thought I’d since fixed it with a change in the Detour settings (turning off Auto-skip vias). I deliberately put a via to turn left on Hey 24 instead of earlier and the routing showed correctly in the power planner, but when I went to actually navigate it it seems to ignore the via point (twice!). Any advice on what I’m doing wrong?
thanks,
Mark
thanks,
Mark
Quote from Guido on 26.09.2022, 21:02I think I know what’s going on. I’ve changed the distance it takes for a via point being marked as ‘reached‘. It used to be whenever you get within 50 meters of a via point. But I changed that to 100 meters two versions back.
I’ll change it back again for the next update. Meanwhile, as a workaround, if possible, place via points further than 100 meters from junctions.
Quote from Ernst on 28.09.2022, 23:18Quote from Guido on 26.09.2022, 21:02... I’ve changed the distance it takes for a via point being marked as ‘reached‘. It used to be whenever you get within 50 meters of a via point. But I changed that to 100 meters two versions back.
It would be great to make this adjustable.
Quote from Guido on 29.09.2022, 06:43No need. (and will cause questions and misunderstanding amongst users).
I will put this back on what it was before. That worked great.
I changed so that users could get the ‘close to stop’ message earlier, but there are others way to know if a planned stop is close: https://scenic.app/forum/topic/stop-in-route-text/#postid-4189
