Forum breadcrumbs - You are here:Scenic ForumUsing ScenicShortcut 1 / 2
Shortcut 1 / 2
What are you Scenic users using the Shortcut 1 or 2 for?
My first gets my distance from home and an approximate travel time and then texts my wife to let her know when I'll be back.
The second is used to get my current location and then add the street name and town to Notes called Great Roads. I use this so if I'm on a particularly good road it gets added to the list for me to look up and add to rides later on.
Old Man Emu and nick123123 have reacted to this post.
Old Man Emunick123123
Quote from Desmo on 21.09.2023, 09:55
I like the sound of that!  I'm an idiot... would you care to share how you did this?
Mex has reacted to this post.
Mex
I think this should work and I've actually improves this from my original. https://www.icloud.com/shortcuts/9a11d3902ded486dbb552bb177ce219b
The link should allow you to download it to your phone. All you need to do is create a new Note in the Notes app called Great Roads.
When you run the shortcut it will now ask if it is a Good Road or Bad Road, also with an option to Exit.
When you click either option it will get your location and extract the street name and town/city and then add it to the notes along with a marker for Good Road or Bad Road.
You can then just look at the notes whenever you fancy.
Bixio and Old Man Emu have reacted to this post.
BixioOld Man Emu
Quote from Desmo on 22.09.2023, 05:49
Doesn't seem to work for me.  I installed the shortcut and configured Scenic shortcut 1 for it.  When I tap the shortcut 1 button in Scenic, the Shortcuts app comes forward (hiding Scenic) and the "Rate this road!" window opens.  When I tap "Good," a notification (I think?) for the Notes app opens, showing the "Gread Roads" note but with no additional text.  That's where my screen stays, the Shortcuts app forward, covered up on top by the Notes notification.  I have to switch back to Scenic if I want to see it and continue to use it.
When I open the "Great Roads" note, I indeed find no additional text...
@mattsz - I opened the shortcut, clicked on "Great Roads" and it brought up a list of Notes files. I clicked on my "Great Roads" in both the Good and Bad flows the clicked "Done". I think you have to do that to make sure the link works to your specific note. Once I did that, it worked for me.
@desmo - Thanks for a great shortcut! I have been wanting to do this and wasn't sure how.
Desmo has reacted to this post.
Desmo
The link should allow you to download it to your phone. All you need to do is create a new Note in the Notes app called Great Roads. When you run the shortcut it will now ask if it is a Good Road or Bad Road, also with an option to Exit.
Hey man ! That is very cool. Works perfectly.
I’ve only been using Scenic for 3 days. Today was my first ride and it was great. I am trying to do a Shortcut to turn off Voice Navigation when I am in an area that I know well. Like the first 10k from my house is 150 round-a-bouts and Scenic is talking to me all the time.
So I just want a shortcut for Voice On/Off and then I can listen to music uninterrupted until I get out of town.
You can use the “mute voice” button in the menu for that. This will prevent voice instructions from playing. Or is this not what you had in mind?
Old Man Emu
Yes, I've been retired for too long. Of course !
I didn't even see that button - focusing too much on the road !!
I did implement the "Send Current Location and estimated Travel Time until Home to my wife".
For our upcoming trip around Tasmania, I will copy and amend to "Send Current Location to my riding buddies - I'm Safe / I Need Help !" if I need to stop for photos or something !
