Scenic Web App & other navigators
Quote from abowen on 22.11.2026, 19:06I've found the new Scenic web app to be a great repository for all my routes. This post is not meant to debate "why" you'd use the web app with other navigators but to focus more on the "how". I've found quite straightforward workflows to export routes from Scenic web app for Garmin XT2 and Beeline Moto II. I also want to use the technology and apps as intended and not have to plug my GPS into my computer or use SD cards to transfer routes.
Garmin XT2 syncs routes using Garmin's Tread app. There's an ongoing bug somewhere in the sync process (within the Garmin system) where shaping points are moved without rhyme or reason. It's been around for years and is well documented at zumoforums.co.uk. The solution to this problem, as of now, is to only use stop points in your routes when syncing routes within the Garmin system (namely using Garmin Tread). Again, this is not a Scenic issue. Scenic offers two solutions to this and it is suggested to rename these stop points to something short as the XT2 will announce each and every one. To get routes from Scenic web app into a format suitable for Garmin Tread app to import successfully, export your routes as plain GPX and deselect waypoints and tracks (unless that is something you require). Optionally, you can use the Scenic feature to convert all vias to stops. The plain GPX format only supports stop points. Then import this file into Garmin Tread app so it syncs to your XT2. You can verify/edit within Tread to make sure the route is accurate.
For the Beeline moto II, I want a native beeline route that will provide point to point routing and rerouting and the ability to edit that route within the Beeline app. Those of you that are Beeline users will know that when you import a GPX file, you do get directions and routing but the route cannot be edited nor will it reroute should you deviate from it. The solution here is to import your routes using "Waypoints only" mode. Beeline will then build a route connecting your waypoints so be sure to use enough to get an accurate route. The general recommendation is to include at least one via point on every important road in your route and your results should be very close if not exactly match your original route in Scenic. To get routes from Scenic web app into this format for Beeline, you do need to convert all vias to stops within Scenic. This time export from Scenic web app as a plain GPX file with waypoints, routes, and tracks selected. Import that file into the Beeline app and choose "Waypoints only" mode and if that choice doesn't appear something went wrong with your export. After the route is imported within Beeline, switch the routing mode from compass to fast/fun/relaxed routing for recalculation and then save your route.
I'm a Mac user and I've tested this all on MacOS with Garmin Tread and Beeline app installed on my Mac. You'll have to use your phone at some point to sync the routes to your specific navigator but this workflow can be completed all on your computer for the most convenience.
Quote from Guido on 22.11.2026, 19:40Thank you for the insight and tips. Of course you can plan with Scenic and navigate with other navigation devices/systems.
There will always be extra steps and possible route differences involved though. The best way to do all this is to use Scenic for planning AND navigating.
I know I’m a bit biased being the dev of Scenic and all 🙂, but even if I weren’t, nowadays, with cheap 3rd party Apple CarPlay, Android Auto displays and ruggadized Android tablets, I don’t see any reason to plan with Scenic and navigate with other systems (with all the disadvantages and extra steps that come with that), unless you already have a Garmin or Beeline of course, and are not willing to write that of just yet.
Quote from abowen on 22.11.2026, 21:09Thanks as always Guido. Scenic is the best motorcycle navigation system available and staying within one system will produce the least amount of friction and best results, if that works for you. There are pros and cons to every choice, handlebar phone mounts, CarPlay/Android Auto units, tablets, standalone GPS units.
