Scenic refuse usage toll roads
Quote from windingroad38 on 16.05.2026, 10:04Hi Guido, I am about to plan a Trip in the alps. No matter which calculation Option I use, scenic refuses to route through this Segment.
If you like to test it: set start Point on the main road in PARTENEN (W3W kindling.croaks.modems) and destination at ISCHGL (W3W total.caravan.fumbled). Normal routing should go via SILVRETTA HOCHSTRASSE (L188-B188}. But part of this is toll road. I am not able to get scenic to route through this, tried almost all options.
I know scenic sometimes has issues with portions of roads where it can not route through. But as avoiding or accepting toll roads is a feature in routing options, I would expect scenic to handle this properly.
Version 4.36
Version 4.36
Quote from Karlchen on 16.05.2026, 10:22Hallo,
ich vermute hier ist das Problem.
https://www.google.com/search?q=sillvetta+hochalpemsztadse+gesperrt&rlz=1CDGOYI_enDE1207DE1207&oq=sillvetta+hochalpemsztadse+gesperrt&gs_lcrp=EgZjaHJvbWUyBggAEEUYOdIBCTE4NDEzajBqN6gCFLACAeIDBBgBIF8&hl=de&sourceid=chrome-mobile&ie=UTF-8#lfId=ChxjMe
Hallo,
Quote from windingroad38 on 16.05.2026, 10:32Das ist in der Tat ein schwerwiegender Grund 😊
mir war nicht bewusst, dass Strassensperrungen mittlerweile in Scenic angekommen sind…
Quote from windingroad38 on 16.05.2026, 10:47Danke auf jeden Fall für den Hinweis…
