Scenic on Graphene OS
Quote from Bastiaan on 17.07.2026, 03:14Does anybody experience already scenic on Graphene OS? I installed it via google play, logged in the app but after that the app try to get my location, wich it cant find. It jus stays there with the pop up not continuing to start up the app.
So if somebody can help me trough this, please. Thank you
Quote from Guido on 17.07.2026, 08:24Hi @bastiaan,
Honestly, we have not tested Scenic on Graphene. However we are using the normal location access prompts required by Android. I’m not sure if Graphene requires some extra location access authorization perhaps?
If you go into the OS settings > authorizations for location access, can you see Scenic there, and does it have access?
Hi @bastiaan,
Quote from Bastiaan on 17.07.2026, 23:58Hey Guido, thank you for your answer. I understand that Scenic is not tested on Graphene. I checked what you suggested. Scenic have location acces authorisation.
Does Scenic need Google play services to run? I have several profiles, Scenic is not in the same profile as Google play services.
I will start a topic on the graphene forum. I hope they can help, I just switched from iOS to Graphene os. I like to keep using Scenic, great app. Thank you for building it!!
