Scenic Link Map Style
Quote from visiongrill on 11.04.2026, 16:50Any chance there is a map style for map appearance on the route link display? If so, has anyone had any issues using it? Other than it would need some alteration to show POIs like fuel stations, I like it.
While I am here another question-The voice I used to use for navigation disappeared when IOS updated to 26. I have been going through some of the other voices and I have a couple of questions about that functionality. I can change some of the speech patterns of the voices but it seems like the only pattern change that Scenic picks up is the voice speed. Any idea why?
I am also going to assume that there is no way to bring in the Siri voices? That would be ideal.
Quote from Guido on 12.04.2026, 07:59Any chance there is a map style for map appearance on the route link display? If so, has anyone had any issues using it? Other than it would need some alteration to show POIs like fuel stations, I like it.
The web-page that opens when you click a share link uses a standard map. You can't customize that map style like you can with the map styles inside Scenic. This web-page is more meant for easy sharing with other people. Not so much for planning purposes and such.
I assume you are referring to the pitch setting in Accessibility? I believe this is new in iOS26, and it's probably used when the voice is used in Apple's own apps and general iOS accessibility features.
Your assumption is correct. Apple doesn't expose those voices to 3rd party apps.
