Routing Issue or Open Maps Error
Hi .. I’m not sure if this is an error with the routing in Scenic or something in Open Maps. I’ve uploaded a couple of screen shots. Planning a route around Sudbury, Ontario, Canada. The issue is with a roundabout. Circled to show general area and then a close up of what’s happening. The routing is forcing the route the wrong way through the roundabout. I’ve tried adding and deleting different via points but it keeps sending me the wrong way around. Both Scenic and Open Maps are showing the correct direction arrows. Any suggestions would be appreciated. Thanks
Looks like a map data error: https://scenic.app/help/reporting-map-errors/
There were two errors in one roundabout (direction of travel in the roundabout and in one exit-lane):
I have already corrected them on Openstreetmap:
sdk has reacted to this post.
sdk
Thank you!
