Route Timeline - CarPlay/AA
Quote from johnsondvr on 23.05.2026, 12:34I generally use CarPlay and love the development of Scenic. One feature that I really miss on CarPlay is the route timeline that is in the app.
Is there any intention of adding the ability to see this feature into CarPlay downstream?
Quote from Guido on 24.05.2026, 16:01I've added it to the feature request list.
This will be limited by the UI templates that apps are forced to use by Apple. In other words... it will need to use the same list template that's used in, for example, the search results.
Quote from MjK on 26.05.2026, 13:52I know it’s not the same as an integrated timeline, but here is what I am doing :
while I am navigating with scenic, I share the active route with another „integrated“ app called weather on the way.
this pp does not only show you exact weather forecast on your planed route for the time you are at your stops - it also has. Weather integrated timeline feature ..
so while you cou could wait til Guido integrates this timeline search kind of feature into scenic you could switch simply to another app, check weather while you scroll through the timeline
have a look: https://scenic.app/forum/topic/weather-integration/#postid-12482
cheers Markus
cheers Markus
Quote from pleasantone on 08.06.2026, 10:03Guido, I was going to ask for this too, thinking a great way to do it would be if you tap the next turn box in the top left (when scenic is the main app, not the Home Screen dashboard) it could expand the box and give us the next several turns.
but I have some feature requests for the second screen we may get when running CarPlay... so I'll continue in that thread.
Quote from Guido on 08.06.2026, 10:12The next turn box is not touch sensitive in the CarPlay template.
