Guido on 13.05.2026, 10:59
It should work, if you have all the offline maps installed for the regions you are traveling through.
Can you check if all your offline map regions are up to date? Side menu > Profile picture > offline maps. If an update it available there will be a big yellow bar at the top.
It shouldn't matter if they are not up to date, but if one of them is up to date, and for another an update is available, then it won't work. All regions need to have the same version.
Also, if you are loading a route onto the main screen, by default Scenic will include navigation from your current location to the route start. If you are in Airplane mode, this means that the regions between your current location and the route start also need to be available offline.
