Round Trip Issue
Quote from ChrisD503 on 23.07.2024, 10:04So, I’m having an issue where when trying to start a round trip from “where to?” the round trip is created but as soon as I try to start the navigation it goes immediately to “Destination Reached” and ends the navigation. I’ve tried many times, but every attempt ends in the same result. Is this a known bug?
Quote from ChrisD503 on 23.07.2024, 10:35Doing it from the power planner, that makes sense. But launching it from the “where to?” There’s no start flag, it just seems to use current position. And the finish flag cannot be moved.
Your point totally makes sense that it’s getting confused because start and end are too close together. But isn’t that the whole point of a round trip?
Quote from Guido on 23.07.2024, 10:36Sounds like a bug. I'll look into it for the next update.
Quote from DaylightsNL on 25.08.2024, 08:10I’m having te same issue.
Quote from NewVers on 14.12.2024, 09:01I’m having a similar issue. I select Round trip and set a 150mile distance and give it a direction - hit go and this pops up.
Quote from Karlchen on 14.12.2024, 09:05Hallo,
Bei mir mit 4.09 geht das ohne Fehler.
Nur zur Info.
Vielleicht liegt das daran, dass ich die Offline-Karte installiert habe.
Start und Stopp ist gleich.
Hallo,
Nur zur Info.
