Rerouting
Quote from Shagen on 04.09.2022, 15:43I'm new to Scenic but am loving it so far. I have yet to sign up for premium as I am still assessing if this is the app I want to use.
I have a question on Rerouting and use version 3.14. I have switched on "Recalculate on detour" and "Selft-Correct" but when I leave the preplanned route, it just shows me where I am going instead of trying to reroute me to where I need to go. Or is this only on a premium account? The text underneath these settings don't say it is a premium feature.
Quote from Guido on 04.09.2022, 15:46I'm afraid Turn by Turn navigation (including display of ETA and DTA, rerouting when you take a wrong turn and voice instructions), has been moved to the Premium plan since Scenic 3. I had to do this because the new map provider is charging me for every turn by turn session. Of course you can always try the turn by turn navigation by using a credit. More info here: https://scenic.app/help/paid-features-and-prices/
I know this is probably not the answer you were looking for, but I hope it at least explains.
If you have any more questions, please let me know.
Quote from Shagen on 04.09.2022, 15:50Thank you Guido. That is fine. I can use a credit to try this feature. I want to try before I buy and this is exactly what all App developers should do.
Can I suggest that the text under those features actually say these are available with premium? Than it is clear so that users might not think the feature is broken or not functioning as intended.
I am loving it so far!
Quote from Guido on 04.09.2022, 15:55Good suggestion. I will adapt the text in the popup (when you start a navigation session) a bit.
