Can I suggest some enhancements to this page? Ok cheers …
1) when you slide or tap your finger across the bottom graph it displays a marker and stats. Can those markers be left in place when removing you finger? It does when you single tap the bottom bar
2) can you tap or double tap on the recorded route spot to pop up a marker and the stats?
3) if there are photos can a double tap open the photo full screen
[caption id="attachment_10454" align="alignnone" width="800"]
