Forum breadcrumbs - You are here:Scenic ForumUsing ScenicRe-routing not working
When using follow the (feint) line I have noticed that re-routing does not happen if you go off route. Also, time and distance to destination is also not available. Am I doing something wrong? Is this a feature that is now switched  off to force subscription in the latest version?
You are correct. The line being feint is a bug and will be corrected in upcoming update. However the actual turn by turn navigation has now indeed been moved to the premium plan. The new map provider charges differently, now for every turn by turn navigation session, regardless of voice.  That's why I had to do this. More info here if you like: https://scenic.app/help/scenic-3-info/
Thanks Guido
Your quick response is appreciated.
This is a bit of a shame for me, as I will most probably no longer use the App. I have no aversion to paying for an App that I use consistently but I don't use it enough to justify the cost, especially when there are many others that work quite well, except for curvy route options.  You have a great product.
I understand and of course every freemium user should decide this for themselves on that.
