Problem accessing my offline maps
Quote from mikearmentano on 29.03.2024, 22:01Hi Guido,
When I try and open offline maps from the profile pic, I get this error: this operation couldn’t be completed (heresdk.maploadererror error 1)
Quote from Mex on 30.03.2024, 00:51Hi Mike.
You dont open the maps you have downloaded.
Its just under your Profile to show you which maps are installed and to show you if they need an update.
On the mainscreen you see the complete world and use it, as you wish.
Offline maps are just downloaded for regions without data connection.
E.g.: been to Monaco in September. Data roaming ist very expensive there, so i used the offline map of Monaco, which i downloaded before our trip. Offline navigation is quite slow, compared to online navigation.
Hope that explains and helps.
Regards, Mex
Hi Mike.
Regards, Mex
Quote from Guido on 30.03.2024, 01:35Hi Mike,
Besides what Mex said, it's possible that Scenic can't get connection to the map server to download the list of downloadable maps. There are a few common causes for that. Have a look here: https://scenic.app/help/map-update-stuck-not-loading/
If you still can't get it to work, please let me know.
Hi Mike,
Quote from Karlchen on 30.03.2024, 02:21Hallo zusammen,
eine Frage dazu. Wenn ich die Offline Karte installiert habe, wird diese der Online Karte vorgezogen?
Falls ja, ist es möglich dass auszuwählen?
Ich fände das klasse wenn Scenic Online vorzieht und bei Wunsch zb um Kosten zu sparen man auf offline vorziehen umstellen kann.
Beste Grüße
Karlchen
Hallo zusammen,
Beste Grüße
Karlchen
Quote from Guido on 30.03.2024, 05:10****English below******
Im Moment versucht Scenic, Ihre Route zuerst mit Offline-Kartendaten zu berechnen. Wenn dies fehlschlägt (weil Offline-Karten nicht installiert sind), wird es online versucht.@Karlchen Was wäre ein Grund für Sie, es zuerst online zu versuchen?
At the moment, Scenic tries to calculate your route with offline map data first. If this fails (because offline maps not installed), it will try online.@karlchen What would be a reason for you to try online first?
Quote from Karlchen on 30.03.2024, 07:25Hallo Guido,
Ja da wäre es.
super wären beide Optionen frei Wählbar.Online zuerst und wenn kein Internet dann offline würde ich vorziehen.
sollten die Kosten zu hoch sein würde ich offline nehmen wollen.
Beste Grüße
Karlchen
Hallo Guido,
Ja da wäre es.
Beste Grüße
Karlchen
Quote from Guido on 30.03.2024, 08:18Im Moment gibt es keine wirklichen Vorteile, zuerst Online auszuprobieren. Denken Sie über etwas Bestimmtes nach?
Quote from Karlchen on 30.03.2024, 08:32Weiter oben schreibt jemand online ist schneller.
zusätzlich denke ich, dass online der Verkehrsfluss und ähnliches aktueller ist.
ist das nicht so ?
ist das nicht so ?
Quote from Guido on 30.03.2024, 08:48Offline ist fast immer schneller und energieeffizienter als online, da es keinen Datenaustausch mit dem Server erfordert. Wenn Sie ein gutes WLAN haben oder ein gutes 5G/4G-Signal haben, wird der Unterschied zwischen Online und Offline nicht wirklich spürbar sein. Aber wenn Ihr Signal nicht optimal ist, wird die Online-Geschwindigkeit schnell abnehmen.
Was die Verkehrsinformationen betrifft. Ja und nein 🙂. Ursprünglich wollte ich, dass die Online-Routing-Engine genau das gleiche Ergebnis wie die Offline-Routing-Engine gibt.
Wie sich herausstellt, berücksichtigt die Online-Routing-Engine Verkehrsvorfälle (Unfälle, Last-Minute-Straßensperrungen usw.) und saisonale Straßensperrungen. Dies ist problematisch, wenn Sie Ihre Routen im Voraus planen, da Straßen, die jetzt, im Moment, in dem Sie die Route planen, geschlossen sind, möglicherweise geöffnet sein, wenn Sie die Route tatsächlich fahren werden. Also arbeite ich mit HERE zusammen, um es zu ermöglichen, Verkehrsvorfälle und saisonale Straßensperrungen auch in der Online-Berechnung zu ignorieren.
Quote from Karlchen on 30.03.2024, 09:23Deshalb dachte ich das online besser ist,
wrnn ich jetzt eine Route plane um Ende Mai in den Urlaub zu fahren interessiert mich eine Straßensperre während der Fahrt mehr wie bei der Planung.
wenn Scenic während der Tour eine Straßensperre selbstständig umfährt ist alles gut und dann kann gerne Offline vor Online stehen.
Beste Grüße
Karlchen
Beste Grüße
Karlchen
Quote from Mex on 30.03.2024, 22:57Hallo Karlchen.
In meinem Fall war es so, dass die geplante Route in Monaco durch Polizei gesperrt war. Daraufhin habe ich gestoppt und eine andere Route geplant. Obwohl ich die Offline-Karte geladen hatte, hat es lange gedauert. Gefühlte Ewigkeit bei 30 Grad im Lederkombi.
Auch das Neuberechnen nach der Sperrung war sehr „träge“.Linke zum Gruß, Mex
Hallo Karlchen.
Linke zum Gruß, Mex
Quote from Guido on 31.03.2024, 09:10OK. I'll add it to the feature request list to add the choice to calculate online vs offline.
@mex... if the route calculation is taking a long time, it typically means that the offline routing engine failed and it's trying online now. You won't see this switch to the online routing engine. For you it means the "calculating route" spinner just spins longer.
