Possibility to improve the visibility and differentiation of some details
Dear Guido,
since I sometimes have problems to clearly identify some details while driving I wonder if you could implement some little changes!?
First I would really appreciate a better differentiation between the actual route after a recalculation and the originally planned route. In some situations (for example when both routes are very close together) it can be hard to tell which is which….  So, would it be possible to add a color adjustment option (and/or a graphic option like a dashed line for example) just to create a bigger difference between the planned part of the route and the active one after a recalculation?
Secondly: I am using Scenic with CarPlay on a Chigee AIO 6. Since I never use its touchscreen while driving but the BMW multicontroller instead I have a problem to operate the + and - prompts properly! When selected by turning the controller certain prompts on the top of the screen like the Stop button are just inverted and change from white to black. The + and - buttons are light grey and there appears only a very thin coloured circle around them when selected. In some situations depending on the selected color, the background (map) and the lighting it can be really hard to see! Wouldn’t it be a good idea to change the behavior of those buttons to that of the others - so black when selected instead of light grey?
Thank you for continuously developing this great app and for the very good support!!!
Gerald
PS.: Just read about your accident after writing this thread! So please take your time to recover and get well again soon!!
There are more important things in life than answering stupid questions….😉
