Forum breadcrumbs - You are here:Scenic ForumUsing ScenicOffline Maps
Offline Maps
Hello,
I would like to purchase the offline maps for all of the U.S. I know they are 75 credits. I have 3 questions. 1. How big are the files for all of the U.S maps? 2. Can I download some of the maps, or do I need to download all of them? 3. Can I download some of the maps, then erase them off my iPhone and download other maps, etc. Obviously I am trying to manage my iPhone storage requirements. I want to have the maps offline when I need them only and not store all of them at once.
Thanks,
Jack
Hi Jack,
You download per state. You can see filesizes in the offline maps section of the app.
You can download state per state. No need to download all.
Yes, you can. Scenic remembers which regions you purchased (in this case all US states) and you can download (and delete) a region any time you want and on any device you want, as much times as you want. Just make sure you are logged in with your Scenic account that you purchased with.
there were one situation where i had no GPS OR no Internet and the german map was downloaded on my Iphone, but when i try to search a location, a error occured. Is there a constallation were the offline-map cannot help, if i search for a location?
Regards Franz
If you have the offline map installed the search should give you results. By default it will search around your current location. If your location can’t be obtained  (no GPS signal) it will use your last known location.
If you are in the power planner is will search around the location where the crosshairs is
Here an example when I search for ‘Berlin’ while I’m in Mexico City
Franz Lang has reacted to this post.
Franz Lang
