Number of recorded position data points
Is there any way to increase the sampling rate? The recorded track tends to “cut corners “ when making sharp turns.
Thanks.
At the moment there is not. The GPS from your iPhone gives a position every second, but in order to save space on your device and on the Scenic server, the number of tracked coordinates is reduced during saving. I'm aware that this can 'cut corners' in sharp turns, but it should be enough to be able to follow this track again. Let me know if that's not the case.
Thanks Guido.
One more "suggestion".
How about including the ability to merge recorded tracks in the same way that the BMW Connected Ride app can do.
Nice to be able to merge tracks recorded on the same day for example.
Thanks again.
Yes. This is on the feature request list. Until that time, there is a bit of a workaround:
https://scenic.app/forum/topic/combining-multiple-scenic-tracks/#postid-3516
