Navigation - complete different route
Quote from Wolfmusic on 29.05.2023, 03:55Hi all,
I created a route, start, vias, finish. Stored. When I select the route, everything looks as programmed on my iPad. When I open the route for navigation or edit on my iPhone, a complete different route between the via points will be displayed. Selecting a different routing option will make it even worse.
any ideas?
thx in advance.
Hi all,
any ideas?
thx in advance.
Quote from Guido on 29.05.2023, 05:49That’s really weird indeed.
Could you make sure you are running
(1) the same Scenic version on both devices. You can see version number at bottom of Settings. Latest is 3.19. If not up to date, update through the App Store: https://apps.apple.com/app/id1089668246.
(2) the latest map version in both devices? Tap profile picture in side menu > Premium & Offline Maps > Offline Maps, if there is an update available there will be a red button on top ‘Update Map’. If so, tap that button.
If that’s not it / or no update available, could you post some screenshots here that show some of the differences?
Quote from Wolfmusic on 29.05.2023, 06:15Guido, thx for your fast reply.
on both devices (iPad and iPhone), version 3.19 is installed, all offline maps are updated.
I noticed, that the iPad shows the programmed route, also after starting the navigation or editing the route. (see next 2 screenshots)
Using the iPhone version shows a totally different behavior
Pls let me know, if you need some other information.
I appreciate your support. 👍wolfgang
wolfgang
Quote from Guido on 29.05.2023, 06:27Ok. I think there is something wrong with the maps on your iPhone. Could you try removing Scenic from your iPhone, redownload from the App Store, login again and download your offline maps again?
Sorry about that.
Sorry about that.
Quote from Wolfmusic on 29.05.2023, 07:42Problem solved!
Reinstalled the app, logged in, downloaded the map for Germany.
Now it shows the original route, also after starting navigation 👍👍👍Thx for your quick and helpful support
wolfgang
Problem solved!
wolfgang
