Marking/rate only parts of a route
Quote from Bani on 15.08.2022, 07:12Hello!
i want to start every post with saying THANK YOU for that greatful app!
It‘s already possible to rate complete routes. This feature is sometimes useful, but i would prefer to mark or rate only parts of a route. Is this also already possible? Or maybe a new feature for the future…
For explanation: i‘m often exploring new routes to get from A to B. And sometimes i have the need to mark parts of the route that were especially nice or bad to drive. That would help me to generate a new and better route for the next time.thanks
br Dominik
Hello!
thanks
br Dominik
Quote from Mex on 15.08.2022, 14:14Hi Dominik.
You may use Powerplaner to great a route filled up with your preferred roads and make it public afterwards.
Regards, Mex
Hi Dominik.
Regards, Mex
Quote from Guido on 15.08.2022, 16:15Hi Dominik,
I understand your request. You want to rate stretches (parts) of a route, not the whole route. For example, a route starts in the city and then goes into the mountains. You only want to rate/review the mountain stretch. I'll add it to the list, but this is a big change. It needs some thoughts on how this would be implemented. Rating part of the route is one thing, but then how would this be visible on the map, etc.
Indeed like Mex says... as a workaround for now, you could create a new route in the Power Planner, with just that stretch and then put that route in a specific folder. Then you can make that folder visible in the 'Show on Map' dialog (3rd button from top left).
Hi Dominik,
Quote from Bani on 16.08.2022, 05:19Hello Guido,
thanks for your fast response!
Yes, for example - i drove a route from A to B and through this route i was going through stretch/part that was especially good und i want to mark it on the planned route with a comment or maybe with a green mark only along the good sector. Or the opposite case - i felt a stretch/part was extremly bad because of road issues and want to mark it red.
These possibilies good be only "notes" like a marking color which overlays the route map or something like this. Maybe this feature also makes only sense for recorded rides.
Your work around is also an good idea to handle this. I'll try how about its practicable.
thanks in advance
br D
Hello Guido,
thanks in advance
br D
Quote from nschoenlaub on 18.08.2022, 00:53Hey.
Maybe it can be realised by cutting the recorded route. So only matter left: how to „mark“ the part (while riding).A) setup shortcuts (Apple Kurzbefehl) and get the gps position in a notice? This works well.
B) …
cheers
Hey.
B) …
cheers
