Imported GPX Route Shows Via Points as Stops
Quote from Deleted user on 16.09.2021, 10:50Hi. I use Myroute-App to create routes and export them as GPX 1.1 files, to then import in to Scenic, via the Web App. I have the maps set to 'openstreetmap' in Myroute and everything seems to work well, except for one issue. When I import the routes in to Scenic, it seems to convert all of the via points to stops which, whilst not a showstopper, is frustrating. Any advice on how to keep the via points or convert the stops back to via points easily?
Quote from Guido on 16.09.2021, 11:04OK. That's strange. I'll have a look at why that's happening.
Meanwhile there is a function to batch convert all stops into via points. It's under the 'more' button at the bottom left of the route editor.
Hope this helps.
Hope this helps.
Quote from Deleted user on 16.09.2021, 12:41Thank you Guido. Appreciate the quick response.
Quote from Deleted user on 16.09.2021, 12:50Hi Guido. I found the batch convert, which worked great - thank you. However, sometimes I need to keep some of the stops (as they are genuine stops for coffee, etc). Is there a way to individually convert stops to via points, instead of batch conversion?
Quote from Guido on 16.09.2021, 12:51yes...tap the marker which you want to convert. In the bubble that appears there is a button
Quote from Deleted user on 17.09.2021, 05:06Excellent, thank you Guido! Fabulous app by the way - by far the best motorcycle navigator out there.....and I have tried everything!
