If I skip a turn, reroute to next point
On a motorcycle, where I can’t always touch the screen, what would be the best settings, if I skip a turn and I know I can just continue straight and make my way to the next road on the trip, I don’t want scenic to tell me to turn around and go back, I want to just calculate a new way to get to the next via. I think if I’m still close enough to turn around, it will tell me, but once I get past a certain distance, I would like to discontinue and find a new way to get to my next point. The settings I have now on the detour behavior page, are “guide me to the first unreached viewpoint “, skip waypoint button on map is toggled on, ask to confirm skipping waypoint is toggled on with these settings. Suffice for what I’m trying to get scenic to do?
It depends. If you use a lot of via points in your route you might want to turn on auto-skip via points. If you use curvy routing, via points will be added automatically. Here's more information on all the settings that are available and what they do: https://scenic.app/help/detour-behaviour-scenic/
