I need a WEB version!
Quote from NHRider on 01.09.2022, 10:54I need to have a WEB version so that I can log onto my PC and plan out a great route on my 36" monitors. I find it discouraging to have to do this on my phone and not be able to see enough of the screen to know and feel comfortable that this would be the best and most enjoyable route I want to take. Are there any plans to make a WEB version and allow the exporting or Bluetooth transfer directly to the Scenic App?
Quote from Guido on 01.09.2022, 10:59Web version is on the roadmap. Not giving out dates. Sorry.
Meanwhile, Scenic integrates with 3 great online web planners.
Furkot.com (very powerful, but can be a bit overwhelming)
Kurviger.de (for your curvy routes)
Google Maps (simple route planning)Scenic can also import GPX files from basically any planner that allows exporting of GPX files.
More info here: https://scenic.app/help/ways-sources-to-import/
Quote from thedocdm on 21.11.2022, 15:33I also would love to have a web version. Glad to see it's on the roadmap. Thank you! Love the app!
Quote from 2BTSquared on 21.11.2022, 21:19Don't know why you'd need anything other than Furkot. I haven't found a better/more capable trip/route planner yet. The integration with Scenic is excellent.
Quote from 2BTSquared on 23.11.2022, 08:52Expanding on this further...
When I first came across Scenic, I thought there was at least one fatal flaw - right out of the gate - in that it didn't have a corresponding web based route planner. It didn't have a complete "ecosystem" where the component parts perfectly work together (perhaps being impossible anyway). However, after playing around with Scenic and thinking about it, this seems like a pretty smart approach. Why waste time reinventing the wheel so-to-speak when there are already excellent trip/route planning solutions out there? Unless you think you have a new/better idea for a solution, or think existing ones can be improved on in a significant/meaningful way, why bother? Wouldn't it be better to focus limited time/resources on making one's navigation app the best it can be? Better perhaps to reach out and collaborate with the developers of excellent preexisting trip/route planners and establish/develop seamless interoperability/integration with your navigation app. I'm already a Furkot user/fan. Furkot may be the best of the best at what it does. If there are better solutions, I'm unaware. As to Scenic, I've been impressed with how well it integrates/works with Furkot. The combination of the two make for a pretty impressive package/solution (perhaps the best that I've seen). At least that's my impression so far (testing/trying out Scenic is still a work in progress).
If Furkot is not your bag, then there are other options as mentioned above - Kurviger.de, Google Maps, My Maps etc. But gain, this approach - developing interoperability/integrating with existing/excellent trip/route planning solutions - just seems like a smart way to go to me.
Anyway... my 2 cents.
Quote from Guido on 23.11.2022, 09:05Indeed this is what I had in mind when starting Scenic. And it's worked well so far. To be honest the requests for a webapp have not been many.
Having said that, I do see the added value of a WebApp. It's just nice to be able to see your routes, rides, vehicles, etc. from the comfort of a big screen.
Additionally, importing from other sources (like Furkot) is not always perfect as these sources can use different maps and routing algorithms. Scenic gets around this by adding via points to force the routing to take the roads the source intended. This works well, but sometimes does take a few minutes to check the route and correct any routing discrepancies during import.
With this in mind, I'm planning to phase the WebApp expansion. Expanding it bit by bit, feature by feature. Currently the webapp is limited to importing files (GPX, GDB, ITN, KML) and Google Maps URLs. So, here's a question:
What would your order of implementation be?
- Route Planning
- Seeing your rides
- Seeing your routes
- Seeing/editing your vehicles
- Seeing /editing your account data
- Anything else you'd like to see?Cheers,
- Route Planning
- Seeing your rides
Quote from mattsz on 23.11.2022, 09:11Quote from 2BTSquared on 21.11.2022, 21:19Don't know why you'd need anything other than Furkot. I haven't found a better/more capable trip/route planner yet. The integration with Scenic is excellent.
It's a worthwhile discussion.
I've tried Furkot, and don't like it at all. In my rural area, many roads aren't displayed until I zoom in so close that I can't see "the big picture." A very troublesome way to plan...
Quote from 2BTSquared on 23.11.2022, 10:09Quote from Guido on 23.11.2022, 09:05Additionally, importing from other sources (like Furkot) is not always perfect as these sources can use different maps and routing algorithms. Scenic gets around this by adding via points to force the routing to take the roads the source intended. This works well, but sometimes does take a few minutes to check the route and correct any routing discrepancies during import.
True. It's not perfect. From what I can tell, all solutions have this problem. Since I primarily swim in the Android ecosystem I've played around with other solutions like - for example - MyRoute-app. The MyRoute Navigation app is HERE maps based. MyRoute Routeplanner has multiple options - HERE, OSM, and TomTom (plus overlays from Google and Michelin). Ideally you'd plan in Routeplanner on the map data used by the navigation app/device you're importing your route/trip to. For MyRoute Navigation that would be HERE of course. Theoretically that should eliminate or at least minimize discrepancies. But in reality, there are often discrepancies between the way Routeplanner routes you during the planning stage and what you find in the route produced by the Navigation app. It's just the nature of the beast. I haven't seen a solution yet that didn't require the step of reviewing the final product on the navigation app. What I've seen so far, however, is that Scenic's approach in this regard is impressive (probably the best I've come across).
- Route Planning
- Seeing your rides
GuidoMy choices would be biased towards my own interest of course. My first priority would be getting an Android solution out there. Second would be continuing to improve the navigation app. After that, then maybe giving the webapp a little love. Going back to my perspective gained with playing around with MyRoute-app... I find that MyRoute Routeplanner pales in comparison to Furkot. However, in terms of learning curve, Routeplanner may be much easier for some to pick up and use. For simple/quick route planning, Routeplanner is pretty decent and there is value in having a simple to use/easy tool.
For those swimming only in the Android ecosystem, Routeplanner provides for a decent tool to review/correct route discrepancies from Furkot (or whatever external route planner that was used) before opening the route in the Navigation app. However, it doesn't preclude the necessary step of reviewing the route again in the Navigation app (making the value of the intermediate step debatable). For iOS users, it isn't debatable. Scenic handles this so well in the app I don't think you need this intermediate step.
If the goal is to make a superior/more capable solution than Furkot, then that seems like a tall order.
As to being able to see one's rides(tracks)/routes on the web app... First question... Does the external trip/route planning app used already facilitate that? If so, what's the value? Perhaps it doesn't, and if so, then it would be handy. I for one, don't do much with/have very little interest in tracks. For routes, I don't need to view the route on a PC in another app besides the route planner that I created it in (in my case, likely Furkot).
All the things you've listed will have value to somebody. To me though, I'm pretty happy with what you have. Again, if time/resources are limited, I might (noting my bias) focus on the priorities I mentioned above.
My 2 cents.
- Route Planning
- Seeing your rides
My 2 cents.
Quote from iSilentP on 23.11.2022, 10:32Quote from Guido on 23.11.2022, 09:05What would your order of implementation be?
- Route Planning
- Seeing your rides
- Anything else you'd like to see?The ordinality above nails it for me. The first three are great enhancements. Anything else is icing on the cake.
Thanks for all you do, Guido. Love the app!
- Route Planning
- Seeing your rides
Quote from thedocdm on 23.11.2022, 12:23Quote from Guido on 23.11.2022, 09:05What would your order of implementation be?
- Route Planning
- Seeing your rides
GuidoReally the only thing I want the webapp to do is route planning. The app is really fantastic for this, but it's still easier on a big screen with a mouse!
In the meantime, I'll give the supported webapps another try. I did not care for them the first go-round.
One last suggestion, is perhaps people could vote with their money? Put a donation widget up (additional voluntary donation) with some features to choose from that people might wish to sponsor. The widget could include the tally in votes and/or currency.
Thank you!!
- Route Planning
- Seeing your rides
Thank you!!
Quote from Guido on 23.11.2022, 13:46OK. Thanks for your suggestions everyone. I'll keep it in mind once I start the webapp expansion.
Regarding the voting... to be honest, not a big fan of prioritizing surveys. It creates expectations, while user preference is just one part of the equation. Other things, like the amount of effort, value for new user attraction, technical limitations, and the 'big picture plan' play a role in this as well. I'd rather ask involved users like you guys, who pro-actively contacted me about this. Hope you understand.
Quote from PeteRT on 24.11.2022, 03:59Personally I would be happy with a planner only functionality, the same as the app, with a way to send the route to your account. I see the bigger screen as an easier route planner. I don't think it needs to be anymore complicated than that. Of cause you could create a web app with login so a user can see what is saved on the server, ie your phone but is that really necessary. You then start to create a complete web version of the phone app. That I'm sure is a lot of work which could be better spent making the app better.
The advantage of a web planner dedicated to Scenic is that the map and routing algorithms would be the same as the phone app. So a route planned on the web would transfer to phone accurately. I have always found using third party planners routes have to be checked carefully for unexpected changes when transferred to the phone.
Another advantage is if the web planner is basically a version of the app planner then there is no new software to learn. Some third party planners are just too complicated. IMHO keep it simple to start with and expand functionality over time.
Quote from hjs rides on 24.11.2022, 14:45FWIW, I use RouteYou to plan routes. Scenic integrates really neatly with that too and can import routes directly.
Different tools that each do a few things *well* still have a place in the world!
Quote from wjsarver on 24.11.2022, 17:37Rever has a pretty easy to use website. https://a.rever.co/rides/new It allows you to make routes and a few other things. Something like that would be fine for me.
Quote from 2BTSquared on 25.11.2022, 11:42Expanding on the need for simple to use trip/route planners. From my experience, they all share the same fundamentals in terms of their functionality and use. Once you've picked up how to use one, you generally are well on your way to knowing how to use another. I often see Furkot getting a rap for being complicated or the learning curve. I find that for basic functionality it's not much different than any of the rest. It's pretty easy to use. If you want to leverage it's more advance features, then one might need to dig a little into the documentation. For the basics though, it works basically like any other.
The problem with simple route planners... What happens when you outgrow them and want to do more with them? Might you feel like you've invested in them and be reticent to switch? IDK... Seems like a reason to start off with a solution that will allow for growth in how it's used.
Quote from JAY on 30.01.2023, 00:30I would like to see a the web app capable to plan my routes on as well. For those of you who are suggesting a third party app that is well and good and at the moment I use google maps but when I am paying for an app I would expect that the app would be able to do route planning on any screen. Scenic is great but would be even better if the web app was complete as well. Hi Guido I think if the web app was able to plan routes and save it to my account so I could then open that route on phone and navigate it that would be excellent . I know easy to want and a lot harder to do. Keep up the good work.
Quote from massi on 30.01.2023, 06:42If you own an Mx Mac, you can run the Scenic app on your Mac, if not there are a lot of apps and web apps for planing routes. You can use f.e. kurviger.de or furkot.com for planning a route, these have the possibility to export the planned route directly to Scenic.
Quote from mattsz on 30.01.2023, 08:53Quote from massi on 30.01.2023, 06:42If you own an Mx Mac, you can run the Scenic app on your Mac, if not there are a lot of apps and web apps for planing routes. You can use f.e. kurviger.de or furkot.com for planning a route, these have the possibility to export the planned route directly to Scenic.
The alternatives you mentioned are discussed above. But I was wondering if anyone was going to mention running the Scenic app on a Mac. I don't have a recent Mac, so I can't do it, but I am curious to know: does running the app on the Mac offer any screen size advantages? Will the display expand to fully utilize the computer's screen, or does it retain the same narrow form factor? I also wonder about how an iOS app, designed to work with a touch screen, would function using a mouse instead...
Quote from Guido on 30.01.2023, 08:57The mac version of Scenic is actually the iPad version running in a kind of emulator. You can expand full screen. If you have a touchpad it works pretty much the same except that you have a mouse pointer. Mouse also works, only pinch zooming with mouse is a bit more cumbersome.
Quote from Darktux on 20.02.2023, 04:13I must say that for me one of the best features of Scenic is the power planner, it is by far the easiest way to design a relativley complex route just using the phone & when travelling that is the only device I carry with me so a web version is a lower priority for me than some other requests.
Thanks for the great work Guido.
KB
KB
Quote from Zoomer on 18.03.2023, 12:33I'll add on to those who want a web browser version for route planning. I understand that other programs can be use for route creation, but that is cumbersome. Furkot is a terrible program. I've tried it many times, and always end up in a furious rage at it. With so much good UX capacity in the world, it is absolutely primitive.
I like Scenic a lot, but unfortunately I end up using REVER at least as often. And sometimes I use REVER to plan routes on my iMac, and then export them to Scenic.
Regarding priorities, Motive Monkey is a dim and distant lower priority than a web route planner. IMHO, naturally.
Quote from 2BTSquared on 18.03.2023, 14:55Quote from Zoomer on 18.03.2023, 12:33I'll add on to those who want a web browser version for route planning. I understand that other programs can be use for route creation, but that is cumbersome. Furkot is a terrible program. I've tried it many times, and always end up in a furious rage at it. With so much good UX capacity in the world, it is absolutely primitive.
I respectfully disagree. Sure... Furkot's UI won't win any eye candy awards and it's use/capability may present a challenge to some, but it's probably one the most capable - if not the most capable - trip planners around. I've dabbled with many of the available planners out there and have yet to find one that is as capable. Frankly... after getting some experience using it and reading its documentation (which is also pretty good)... it's use seems pretty straight forward to me.
Quote from Zoomer on 18.03.2023, 22:48I'll respectfully maintain my opinion, but I don' t need to convince anyone else or convert them. I do like the extras that Furkot has, including sleeps and eats and fuel stops and other broader trip planning features. None of those features compensate for its cumbersome route planning interface. It has the extras, but fails at the basics.
No matter. I'm glad Furkot exists and that it works for some. I have and use REVER and Scenic, and I think Scenic is, on balance, the best route planner. A web browser planning feature would be a marvellous addition.
Quote from NHRider on 19.03.2023, 06:24I added this post because it’s always best to have a native app planning your trips and can without any issues, import it or even better have it saved as a Trip as you are building it and don’t have to import it into the app. There has been many posts about use this or that and all incredibly good feedback. However, we should be taking this feedback and using it to create a native Route planner that is married to Scenic so there are no issues in importing other maps routes. I’ve had such a terrible time with this from having the app not understand all the turns and or stops so every road that’s turned onto is a waypoint! Totally obnoxious!!! To Unable to import without errors. Please check your route for proper waypoint. Bla. Come on Man! Let’s build the best planning site based on all your feedback and the features but easier to use controls then FUBR or what’s it’s called. You said a web version was coming! Let us see and help see what there and offer feedback as to direction!
Quote from 2BTSquared on 19.03.2023, 07:53Deleted. Post got duplicated somehow.
Quote from 2BTSquared on 19.03.2023, 08:03Quote from NHRider on 19.03.2023, 06:24I added this post because it’s always best to have a native app planning your trips and can without any issues, import it or even better have it saved as a Trip as you are building it and don’t have to import it into the app. There has been many posts about use this or that and all incredibly good feedback. However, we should be taking this feedback and using it to create a native Route planner that is married to Scenic so there are no issues in importing other maps routes. I’ve had such a terrible time with this from having the app not understand all the turns and or stops so every road that’s turned onto is a waypoint! Totally obnoxious!!! To Unable to import without errors. Please check your route for proper waypoint. Bla. Come on Man! Let’s build the best planning site based on all your feedback and the features but easier to use controls then FUBR or what’s it’s called. You said a web version was coming! Let us see and help see what there and offer feedback as to direction!
Might be unrealistic expectations. I've used other solutions that have mobile apps and native route planners (their own ecosystem if you will). I haven't seen one yet that didn't produce discrepancies between the route planner and the mobile app even when they both use the same map data source and there was judicious use of shaping points. Some solutions allow you to navigate tracks (including Scenic). Problem with those, you lose waypoint information and you can still find discrepancies (generally more rare and minor) in the route generated by the mobile app.
For comparison... I use MyRoute-app on my Android phone. It has it's own native route planner (Routelab/Routeplanner). Routeplanner allows you to create routes on the map data (OSM, HERE, TomTom, etc.) that's used on the target device/application. My target application is MyRoute-app (either Navigation or it's new replacement (in beta) MyRoute-app Mobile). Even with staying in the ecosystem here and using the same map data, you still have to verify that the route generated by the mobile app doesn't have discrepancies.
Given that you still have to do this verification step, which solution makes the process less onerous? Furkot/Scenic or Routeplanner/MRA-Mobile? It's no contest... Furkot/Scenic blows away MRA in this category. When you import/open your Furkot trip in Scenic the track is already overlaid on the route, making the process of detecting/correcting discrepancies quick and easy. MRA can also overlay the track on the route for this use, but it's process for doing so is more onerous (and again it's the solution with it's own route planner/ecosystem).
I've looked at various other Android/iOS navigation solutions out there. When I have, a statement in a review always comes to mind...
http://www.globeriders.com/article_pages/article09_furkot/article09_furkot.shtml
The majority of Motorcyclists today use a GPS or Mobile App to navigate their rides. GPS tech and Mobile Nav Apps have changed quite a bit over the years but very little has changed in the way we plan our rides. We typically have maps spread out all over the place, our route editor open and two or three browser windows open with various sources of travel information that we may want to include in our ride.
Every couple of years there's a new crop of online route creation applications trying to get our attention but most of them offer little more than the same route path creation tools. Some of these new 'planners' bill themselves as 'simple to use' in their description which usually translates to 'nothing new here'. Community-sharing seems to be the highlight for most of these apps and some even have contests to differentiate themselves and pay their bills. There are a few ride-sharing websites that actually do share their ride data without you having to pay for the privilege of accessing someone else freely shared ride data - I'll point them out later in this article.
Most of the route generators and planners do very little, if anything, to actually help you plan. So, why is this? The world is full of interesting people, cool roads, places to see, places to overnight, more cool roads, history and geography and all of that information is available for free on the Internet - but not in your Trip Planner. Until now, that is.
Right now... the only mobile navigation apps that appear to be worth my time are Scenic and MRA. Scenic right now is the best solution out there in my opinion. The MyRoute-app Mobile beta (still being developed) is showing a lot of promise and may give Scenic a run for it's money when it gets released. Route planning - it's almost exclusively Furkot. I might use Routeplanner for simple stuff or to overlay tracks on routes for discrepancy correction, but other than that, Furkot gets the nod (for use with both MRA and Scenic).
Personally... I would prefer what limited resources there are being focused on maintaining/improving the mobile app (and making Android Auto a reality) vs. being consumed with creating a native web based route planner for which there isn't much to be gained.
My 2 cents.
My 2 cents.
Quote from alextraveler on 19.03.2023, 08:32What about running Android Scenic app on Windows? I don't know how much effort it would take to make Android app resizable, but it will probably be less effort than creating a web app. I've played with Yahoo mail Android app and it worked well on a big screen. It felt like a native Windows app.
Quote from 2BTSquared on 19.03.2023, 08:43Quote from alextraveler on 19.03.2023, 08:32What about running Android Scenic app on Windows? I don't know how much effort it would take to make Android app resizable, but it will probably be less effort than creating a web app. I've played with Yahoo mail Android app and it worked well on a big screen. It felt like a native Windows app.
Right now there is no Android Scenic app... Word has it, Android Auto will be a thing for Scenic sometime this year.
I could see what you suggest as being handy, but it may still have the same issues with discrepancies that have to be checked/corrected.
