How does Scenic work with Multi Day routes?
Quote from Hubcap on 24.03.2023, 14:19I have been planning a route for an 8 day trip in Furkot. Using Furkot's 'stay the night here' overnight stop at the end of each day. I will be closing Scenic on my phone when I arrive at my 'stay the night'.
My questions are:
- Will Scenic recognise the overnight stop and if so, how does that show in the Scenic App?
- Does Scenic recognise the date (set in Furkot) for each over night stop?
- If so will it automatically route me for the relevant date by the date on the iPhone?
- When I open Scenic the next day, will it resume the navigation at the overnight stop, or will it try to route me to the Start again?
- If I open the app a distance away from the overnight stop, will Scenic route me back to the overnight stop before routing me to the next waypoint or stop.
Would it be better if I created a separate route for each day and overnight stop?
Thank you - I am enjoying learning Scenic
My questions are:
Quote from Guido on 24.03.2023, 16:41It's a bit simpler than that in Scenic.
When you import this trip into Scenic (using the furkot row in the Import screen in Scenic), you'll notice that Scenic split up the big Furkot trip in one route per day. You have to import and save those routes separately.
I recommend creating a folder in your route list, and saving these routes in that folder. Then, every day you select the route for that day. I also recommend saving the ride at the end of each day and saving those rides in a separate folder.
So... at the end of your trip, you should have 8 routes and 8 rides in Scenic.
Quote from Alan on 21.06.2023, 12:07Guido, I imported my daily routes from furkot no problem. In the newly created folder are all my daily routes. They are ordered Day 1, Day 11, day 2, day 10, day 5, Day 7. Is there a way to manually sort them to Day 1, Day 2, etc?
Alan
Alan
Quote from Guido on 21.06.2023, 12:29Hi Alan,
At the moment there is no way to manually sort. Perhaps you could try to sort on newest first or oldest first (if you imported them in order). Otherwise rename them to Day 01 and Day 02. and sort by alphabet.
Hope this helps.
Cheers,Guido
Hi Alan,
Hope this helps.
