Garmin zumo xt
Quote from Bikingcritter on 12.04.2026, 14:50I've asked this question before and still not got a perfect explanation
I have some awesome routes planned on scenic, i want to send it to garmin zumo xt and be mirror image, identical to what I've planned
how am I best sending and saving on
zumo?
last time i tried it sent me on a heavy motorway link way
zumo?
Quote from Guido on 12.04.2026, 15:49Perhaps someone with a zumo can explain the best steps. There are also some threads on the forum around this already. Here's one: https://scenic.app/forum/topic/route-export-to-garmin-zumo-xt/
From Scenic perspective, you need to export the GPX, and then use the Garmin Drive app to get in onto the Zumo.
Two important things....
1) Scenic uses a different routing algorithm so it's possible that Garmin's / the Zumo's routing algorithm takes different roads between the waypoints.
2) GPX files do not have any knowledge of the routing mode and avoidances that you chose in Scenic. So, the Garmin / Zumo will apply some other routing mode.Cheers,
Quote from Guido on 12.04.2026, 15:51Obviously the best is of course to switch your Zumo for a CarPlay unit like Carpuride or Chigee. Then you can just use Scenic for navigation as well, and you completely get rid of this problem all together 😉. In the "Special Offers" section in Scenic side menu, you'll find some discounts for these units.
Quote from Marts on 25.04.2026, 18:33Quote from Guido on 12.04.2026, 15:51Obviously the best is of course to switch your Zumo for a CarPlay unit like Carpuride or Chigee.
And this is what I did eventually. I found the XT's navigator to be quite annoying at times, trying to send me down dirt tracks thinking that they're the quickest way to my destination despite them being just that - tracks which are dirt and I had "avoid unsealed" checked.
