Enlarge some parts
Quote from Jimmy999 on 11.03.2026, 03:24Last days of 2500km ride and I love how I could make the Speedo 150%. Could we get that for any other screen parts. Eg I use stops to measure/count down to major turns off etc, but it’s too small to read on the iPhone 11 I have dedicated for nav. If I could increase km to next stop, the panels in the bottom left showing distance to ride end and the delete next via/stop etc it would nice. Not essential, but it could be nice.
also, we used to have a nav setting that would ignore a via if greater than x km away, now it ignores after x recalls. The previous logic is easy for humans to follow, is the previous logic tied to the previous maps, or have you moved away from it for other reasons?
cheers
cheers
Quote from Guido on 11.03.2026, 16:07I assume you are using your phone in Landscape mode? Or are you on CarPlay?
Some of these texts will increase if you increase your font size in iOS Settings. Other parts I deliberately fixed the font because of limited space being available on smaller phones. The text would get cut off if font would become too big.As for the auto-skipping via option. Indeed in previous versions (pre October 2024) it was possible to only auto-skip via points if they were in a certain radius. I have not implemented this with the new map provider. There are already so many settings for detour behaviour making it difficult to understand as it is. Adding yet another setting would make it even more complicated / add more confusion. Here's a help article on the possibilities now: https://scenic.app/help/detour-behaviour-scenic/
Quote from Jimmy999 on 11.03.2026, 18:36Thanks for the reply. Yes iPhone 11 in landscape dedicated for scenic. No car play. I’ll try the iOS settings.
how quick does it do recalls when missing a via or stop? To me it seems that recalcs are system terms and more difficult to understand than Km from via. But I can make it work either way if I can can understand the recalcs frequency.
i love using scenic and tell everyone every chance I get to use it. Thanks.
