Enhance the display of unpaved roads in a route
Hi Guido, the display of unpaved segments is now very clear in ride planning mode but once the route is set the unpaved segment is very faint, like below from 16 to 20.
Generally I can remember these but if I load an old route or when I share a route with a friend it is not immediately obvious.
Can you make the dashes in the planned segment darker - black or brown like the unplanned display (below 20 for example).
Thanks for your continued efforts.
Hi „Old Man Emu“,
in driving mode the route line is overlayed over the map. So making the route line a litte more transparent may be of help to you. It can be set under Settings -> Appearance & Colors (or similar, I amusing German).
In planning mode:
Driving mode with 10% route line transparency:
Driving mode with 50% route line transparency:
Have great and safe trips, Martin
Old Man Emu
Thanks Martin, that works well. I’ve set it to 90% transparency.
Gary
I'll also look into this. In Scenic 3 unpaved sections in the route were given a yellow/brown color. I'd like to do the same for Scenic 4. Will look into that.
Old Man Emu
