Guido on 29.11.2022, 11:03
Do you mean you want to pick up an existing route somewhere in the middle? If so, here's the answer:
Select the route through the 'where to' button, but then before you tap 'Start Navigation' tap the 'Join route at' option just above it. There you can select where/how you want to join the route. For example, you can select there "I'll find my own way". That will let you find your way to the route by yourself, and once you reach it, navigation will start from the 'join' point towards the destination (in the direction you originally designed the route).
