Different Routing Options between Waypoints
the organiser of a riding event has created the route at kurviger.de - see hardcopy. There I saw an option which I never seen before but it is very helpful for planning rides with different routing options. Between every two waypoints you can select an individual routing option like fast, curvy, very curvy, …
ke fast, curve, very curvy, …
Is it on your list to implement such helpful way for planning in scenic?
Best regards … Thomas
Not possible at the moment as Scenic’s routing provider only supports one routing mode per route. You CAN import these routes from Kurviger through the send to Scenic button. By adding additional via points Scenic can calculate the same route as Kurviger.
Ways and sources to Import
Too bad that it’s not possible at the moment … The curviger route is already imported and with additional waypoint a bring the route on the same way. But it is more working to do that. I hope it will be happen in the near future.
This is the only feature I'm currently missing in Scenic.
Would this be on the roadmap for Version 4?
thomas_1802 has reacted to this post.
thomas_1802
