Curvy and Beauty routing for "moped" option
Quote from MNVespaRider on 13.04.2026, 13:09Hi,
I recently discovered your app, and I really like it. I have a Vespa GTS – 300. While it's capable of speeds up to about about 80 MPH, I like to travel on roads which the speed limit is around 60 MPH. The way people drive around here, that means 70 mph. I'm uncomfortable at that speed with a little margin if I need to speed up. I really like being able to set the speed limit. I was disappointed to find the "curvy" and "beauty" routing options are not available when set to "moped". I use this selection because it's the only one that seems to have a speed limit setting. Would it be possible to allow "mopeds" to select beauty and curvy routes, or add a speed limit setting to "motorcycles"? Thank you. Your app is truly amazing.
PS Maybe label the moped as "scooter", or add an option for fast/maxi scooters. Thanks!
Quote from Guido on 13.04.2026, 13:34I will add it to the list. We are dependent on our routing providers for Curvy and Beauty. At the moment they only offer these algorithms for motorcycle and car. That's why it's not available for moped in Scenic either. I will need to ask them to also make it available for moped.
Another option would be to add a max speed to the motorcycle routing. That might be easier.
I'll add to the list and once I have time to look at this, I'll see what the best option is.
Quote from MNVespaRider on 13.04.2026, 14:39Hi Guido! Thanks for the prompt reply. I agree, it sounds as though adding a speed limit to "motorcycle" would be the easiest approach. The highest posted speed limit in the US is 85MPH, on a toll road in TX, but everywhere else the max is 80 MPH (most people go closer to 90). I just subscribed to your app. It's really good. I'm telling my scooter friends. Thank you!
Paul
Paul
Quote from mattsz on 13.04.2026, 15:42Quote from MNVespaRider on 13.04.2026, 14:39The highest posted speed limit in the US is 85MPH, on a toll road in TX, but everywhere else the max is 80 MPH...
In Texas, maybe... 😜
