Crazy time calculation for extra curvy routes.
Quote from Diggsmc on 29.04.2020, 22:52I am getting wild times listed for routes when I generate extra curvy. It stated that a 150 mile trip was going to take 10 hours, which is obviously not correct. Anyone else have this problem?
@guidomm
I have attached pictures for examples.
Quote from Guido on 29.04.2020, 23:25For the second screenshot (the route you created) could you you edit the route and try and change routing mode to efficient? See how that impacts duration?
The ‘short’ routing mode (used when generated extra curvy routes) and the ‘fast’ routing mode use road speeds provided by the map data, which in some areas is incorrect or incomplete. The ‘efficient’ routing mode overrules those speeds with specific speeds per road type. I can change these speeds for the ‘efficient’ routing mode.
If efficient gives better durations I might change the code so that it also uses efficient mode when generating extra curvy.
Quote from Diggsmc on 30.04.2020, 00:43Using efficient made the time waaaay better. See attached screen shot.
Thanks so much for the quick response!
Quote from Guido on 30.04.2020, 13:24Great. Thanks for letting me know. If/when you get a chance to ride this route, could you let me know how this estimated duration compared to how long it actually took you?
