Connect more routes
would love a feature where I can connect several routes to one route.
Etc. I have planned day1, day2…. Now i will connect the routes to one…
I recommend to keep one route per day. One big multi-day route takes more time to recalculate if you detour and, if extreme, can even cause the app to crash.
For the moment, I recommend to create a folder and place all the routes of that trip in that folder.
I am planning to add a view in the future. A view where you can see all routes in a folder on the map at the same time.
trshot has reacted to this post.
trshot
Thats sound good 👌
But then i need a split route function 🤭
You can see the other routes now if you choose it in the “show” menu?
I have just created one route from others that way.
Yes
https://scenic.app/forum/topic/split-a-route-in-multiple-days/#postid-3982
It can be useful to merge and split routes.
I am currently planning a 10-day trip. It is a puzzle to cut the round into 10 balanced parts.
For example, to link 2 or 3 days and choose a new overnight stay. You can then split it again into days, keeping the route.
Hi GHJ,
I planned 4x 10-day trips with Scenic and I know what you mean. I managed to find a simple workaround. First I import all the POIs (in my case its 200+, because we are using often unmapped off-road trails) I am planning to pass. Then I create a route for each day connecting them as stops. For those days I am unsure where we endup, I make the route longer at the end (or beginning).
Needless to say we do have certain day-finishes fixed (e.g. in case of a booked accomodation en-rote). If you dont have any, this approach might get a bit frustrating towards the end of your trip. In such case, I would suggest at evening to just connect the remaining POIs for the next day - to make this task easier, my POI names always start with a chronological number and then optionally a description. While merging and splitting (I guess, there is a simple workaround for splitting) routes certainly might be a useful functionality, I think it would be of little help in your case because if you deviate so much from the expected timeline, chances are you also deviated from the route.
Just as a suggestion for the split-route problem:
Plan one big route, and then copy it for each day, and delete the way/via point's you don't need with the multi delete function.
I'm not sure, but it might work.
BR
Mario
Yes this works, and is in fact also what I recommended in the past 👍🙂
