Charge IPhone and use Scenic while driving
Does anyone have any clue?
When I connect my IPhone to the scooter with the charging cable it charges. Also still when I start Scenic. When I drive off, it no longer charges. It is not a mechanical problem (plug contact or similar). When I stop again and unplug it briefly and then plug it back in, it charges again. At the start of the journey again not.
I would be grateful for a solution!
Greetings Klaus
Does your outlet have enough power. a 10 watt (2 amp) charger is recommended to be able to charge while running a navigation app. Also make sure it’s a good quality charger and cable. Some (Chinese) ones might say they are 10 watt while they are actually not.
It could also be an electrical problem  when you start riding typically the voltage of your electrical system of the bike changes a bit (becomes higher, to charge your battery etc)
I don’t believe this is Scenic related. Try running another navigation app and see if it happens.
I marched off with meter and various cables and started with old plug, old cable and Google navigation - and it woked. Without having changed anything, it also worked with Scenic ...
Had to explain my phone probably first, how it can be done :-).
Thanks Guido for the quick response - perfect! Best Klaus
Don't underestimate the temperature... direct sunlight, GPS, and charging... all three of those activities generate heat in your phone.
I have the same issue:
Using an iPhone X with a 5v 3.1 amp charger, when using scenic the battery lasts only about 4-5 hours.
I don’t have this issue when using Google or Apple navigation!
I have tried a different charger, same results. I have tried placing the iPhone into “airplane mode”, same results.
I’m using Scenic to map my local riding, but revert to DeLorme Atlas and Apple navigation when traveling or running any route longer than 150 miles
Hi FLMike.
In my case i use a rav power conentor 5V 4.8 A.
While i use Senic theres nothing else running in the backround, but Spotif*.
I tested iPhone SE 2016, iPhone 7 (used one, just for riding) and my 11 pro. No problems, even when we ride 9 hours.
Without charging battery will last for roundabout 2.5 hours.
Dont think it has something to do with Scenic.
Of course Scenic needs more power than google maps, but your setup shut be able to keep up the power-level.
I‘d try to test this with a powerbank.
Same result: Senic is guilty 😎
Diffrent result: Setup is guilty.
Regards, Mex
Quote from FLMike on 22.07.2022, 12:33
I have to admit it's very strange that you do not have this problem with Google Maps or Apple Maps. That would indeed point into the direction of Scenic as the culprit. Then again, the difference simply can not be this big. Your iPhone's biggest battery eaters are, number 1, the screen. If the screen is ON, in full brightness, that's the biggest battery eater. Brightness level (so environment light) makes a huge difference b.t.w. In bright daylight your screen will be on full brightness. On cloudy days and/or night and/or shaded from the sun, the brightness might be lower and thus use less battery.
The second biggest battery eater is the GPS receiver. While there might be slight differences in how Google Maps, Apple Maps and Scenic utilize the GPS receiver, the difference can't be THAT big. Navigation apps simply need high accuracy GPS signal.
Then there is CPU, GPU usage, bluetooth connections, wifi or cellular. These all make a difference and from that perspective it is possible that Scenic uses more battery, but again, the difference can not be that big.
So, my recommendation (similar to @mex recommenation above):
- Make sure you test this in same circumstances. Same ambience light conditions, same connected bluetooth devices, same route, etc. Same other apps running in background, etc. In short... keep everything the same except change the app.
- The other way to test this is like @mex recommended above. Keep everything the same except your charging solution. That will tell you if it's your charging setup.
As a sidenote, in just about all these cases I've heard over the years, it has always been someones charging setup. We even had a user test Scenic's battery usage and it was inline with other nav apps. Have a look at this thread a very similar discussion, and the result of the user's test: https://scenic.app/forum/topic/power-consumtion-scenic-app/
As it turns out Guido is right again 😎
I had an intermittent issue with my USB-lightning cable. It showed the phone charging, but wouldn’t charge at a satisfactory rate… a swap of the cable and it’s working great again!
Happy you found the solution!
Hi folks.
As i thought. Nice to hear it is just the cable.
Cheapest solution.
Nice community in this forum.
Guys, enjoy the rest of this weekend.
Regards, Mex
Totally a wiring/charger thing. Nothing to do with the app itself.
i’m using scenic on iphone 7 & iphone 8. Connect and charger when my trip starts, and keeps charging all the way, even with other apps open
I use a Quadlock wireless charger.
Very convenient but power too low to last a full 8 hours on a very sunny day.
Using a quadlock battery with wireless charging adapter during the stops, saves my day.
Hallo,
ich verwende von SP Connect Kabelloses laden mit Vibrationsmodul.
Das schützt auch die iPhone Camera.
Ich habe das Ladekabel bei mir am fest eingebauten Zigaretenanzünder angeschlossen.
Mein Handy wird auch bei Nutzung von Scenic aufgeladen.
Ich weiß von einem Freund, das auch bei Anschluss am Abblendlicht aufgeladen wird.
Ich bin sehr zufrieden mit SP Connect, und ich bin ca 10.000 km damit gefahren.
Anti Vibration Module
Beste Grüße
Karlchen
I personally have gone back to normal cable charging. Because:
(1) Wireless charging generates heat, and can puts the phone in "overheat protection" mode more quickly (This might not be a problem depending on where you ride, but in Mexico, I found this to be a problem)
(2) Wireless charging (at least the quadlock one I used) does not have enough capacity to keep up with energy concumption of navigation apps combined with full brightness.
So... I've reverted to cabled charging again...takes just 5 seconds more to plug in the cable each time I get on the bike, but no more overheating, and enough charging capacity.
Yes,
that will be my strategy for coming summer too: cable into phone instead of into wireless charger.
Already contacted Quadlock a couple of months ago but at that time no plans for a more powerfull wireless charger for motorcycles there.
As I agree with you the wireless charger generates heat, it the hot Italian sun last year using a cable did not help either ..
what I found as a real ‘cool’ solution is the following:
it is a 15W wireless charger with a semiconductor cooling - these chip is pretty effective and did support running the iPhone in the full sun all day without any issues at all..
As I wann have the phone easy to detach for making photos or simply walking away, this solution, and I testes several of those chip based cooling chargers, was the best solution I found so far - and even pretty cheap
Good tip. Thanks.
I am a bit doubtful wheter the phone will be secure enough on bad or off-road stretches. That is why I opted for the quadlock originally.
but you are right. This is not very expensive. Worth a try.
thanks,
Georges
