changing map style during navigation or tracking
ist there a chance to add the possibility to change the map style during navigation or tracking. I use different map styles on- and offroad (maybe some others do so as well) but during navigation or just tracking, I cannot change to a different map style to go offroad. I need to stop and save the track to change the style and than re-start my navigation which ends up in several tracks instead of just one after a day.
Thomas
Melbara has reacted to this post.
Melbara
You can...  but not directly on CarPlay.
So, if you are on CarPlay, first switch to another app on CarPlay. This will make Scenic active on iPhone.
Then on iPhone, move the map slightly and go to Edit/Change route. Then you'll see the layers button there, where you can change map style.
Hi middlefranke,
a workaround could be:
Use your preffered offroad map style and select it for: dark apperance.
Then you just need to toogle between mapstyles when you go offroad.
Maybe your bike got daytime riding lights, you just switch headlights on and your carplay will switch to dark mode.
Or you cover the sensor of your carplay device and it will switch to dark mode immediatly.
Just my 2 cents, Mex
thanks Guido, I was not hoping to get a Carplay solution but was under the impression the layer button is when pressing the 9 squares in on the right side to get to the navigation menue. When doing that you also get to the layer symbol but w/o the possibility of changing the map style.
Anyway, thanks, thats what I was looking for.
@Mex,
thank you, thats would also be an option - just need something that does not get lost……the other problem is when using it on my bicycle w/o Carplay.
Thomas
I have to bring that topic back again, because I was facing the issue again and recogniced, “yes it works as described” but only of its not running on Carplay. The mapstyle with Carplay changes only when I kill the app and start scenic again.  Is that maybe just a bug?
Thomas
