Carpuride using
Quote from GS Peter on 21.07.2024, 10:01I am using Senic with an external Display (Carpuride) direkt Funktion Buttons are not displayed on this additional Screen. Does somebody know i can adjust this?`
Quote from Guido on 21.07.2024, 11:17Not very familiar with carpuride bur from what I understand it’s basically a CarPlay unit (at least from Scenic perspective). Have a look here for more information what is possible and not possible with Scenic on CarPlay. https://scenic.app/help/handlebar-controllers/?seq_no=2
Quote from QFuss on 11.07.2025, 11:06Quote from Guido on 21.07.2024, 11:17Not very familiar with carpuride bur from what I understand it’s basically a CarPlay unit (at least from Scenic perspective). Have a look here for more information what is possible and not possible with Scenic on CarPlay. https://scenic.app/help/handlebar-controllers/?seq_no=2
Hi Guido. This time I have something I would like to ask at the forum.
Just received the W702 standard device. Need for that easy to explain, My iPhone 13 pro display turns black even in "regular sunny days". Hope the W702 helps.
No familiar with the W702 yet, but found something can't explain. Apple carplay running, scenic is displayed on the device. Iphone display turns black. Ok. But no selection of my routes displayed on the W702. Is this intended?
Means. First select route, the activate Apple carplay.
Hmmmm
best regards
Jürgen
Hmmmm
best regards
Jürgen
Quote from HighPeakRider on 11.07.2025, 11:35If you have set the Carpuride up correctly, IE Bluetooth and the WiFi connection , you press the search button, then routes and the folder and route you want to select.
Quote from QFuss on 11.07.2025, 11:55Ok
Need to try and learn. Also, connect the Cardo Packtalk.Unfortunately, no doctor’s permission to go out for a ride. Have to wait. 🙈🙈
Thank youJürgen Seidel
Ok
Quote from sdk on 11.07.2025, 15:15Quote from QFuss on 11.07.2025, 11:55Need to try and learn. Also, connect the Cardo Packtalk.
Unfortunately, no doctor’s permission to go out for a ride. Have to wait. 🙈🙈Time to get familiar with the new toy 🙂
Do not pair the Cardo with the Carpuride.
Pair the Cardo with the Phone.
Pair the Carpuride with the Phone.Here is a Video of the pairing Process. You want "Method 2": https://youtu.be/ozwV3WRQnFk
This way, you can use your phone with the intercom when the carpuride is not present / powered on. It's also better sound quality.
Have fun!
Have fun!
Quote from Middelfrangge on 14.07.2025, 13:41Hi,
if your iPhone turns black, you still have your screensaver on, that need to be turned off. You can start the route before connecting to carpuride or using the carplay functions. As Guido wrote, carpuride is just a Carplay display thats it - you need to follow the instructions of scenic how to use carplay.
I do have as well aCarpuride 702 in combination with an iPhone 15 and Cardo Packtalk edge. As explained before, do not connect your Cardo with Carpuride, it is sufficient if it is connected with your phone.
Thomas
Thomas
Quote from QFuss on 16.07.2025, 08:22Hi
Mechanical and electrical installation of the W702 at den NavBar of my old 1200gs took longer than expected. But, this is a seperate story that does not belong here
Result of todays test!
1. Carpuride is connected to my older IPhone 11 via wifi AND Bluetooth! Strange?!
2. When I start Scenic the display on the Iphone displays „map is displayed on Carpuride“! Is back on the the Iphone ss soon as I close scenic on Carpuride!
3. Same story with OSMAND!
4. Different with calimoto. Map is displayed on Iphone AND Carpuride.
There must be something odd in the settings, either Carpuride, Iphone, Scenic, OSMAND.
Might almost impossible to get down to the reason.
Will check for other users in my biker Community (United Bikers Koblenz).
Thank you so far.
Stay healthy!!!!!
Hi
Thank you so far.
Stay healthy!!!!!
Quote from Guido on 16.07.2025, 09:21When Scenic is active on CarPlay it is normal that the iPhone screen says “Scenic active on CarPlay”. Every app will do this differently, depending on how the app is developed.
Quote from HighPeakRider on 18.07.2025, 15:14@qfuss
What you should see is the Carpuride connect via Bluetooth then once connected the Carpuride creates a wi-fi connection to the iPhone, then the Bluetooth connection is disconnected.
https://carpuride.com/blogs/guide/carpuride-connection-guide-common-issues-and-solutions
Quote from QFuss on 19.07.2025, 10:43LOST I GIVE UP
Guess something is deeply wrong with the way how I did the setting. Don‘t get the audio established.
Not only a scenic issue. It is the case with OSMAND, Calimoto, Google Maps as well. But also with the Android Samsung S 20 5G and OSMAND.LOST
Contacted Carpuride. Hope to get their answer soon.
Thanks for all your support
LOST I GIVE UP
LOST
Quote from QFuss on 20.07.2025, 05:18SOLVED SOLVED SOLVED SOLVED
So stupid!
Have to change on the iphone the audio settings from carplay back to iphone / bt headset! That‘s it!
So stupid I am!!!
thanks to everybody at the forum
Jürgen
So stupid!
So stupid I am!!!
Jürgen
Quote from HighPeakRider on 20.07.2025, 08:26This makes it easy
2. Select Audio Output Mode
After pairing, select the appropriate audio output mode on the main Audio Output interface.
BT Trans Mode: Connect the Bluetooth headset to the Carpuride device, please delete the Bluetooth headset connection record from your phone to avoid simultaneous connection, which may cause improper working issues.
iPlay/Auto Mode: Connect the Bluetooth headset to your phone, please delete the Bluetooth headset connection record from the Carpuride device to avoid simultaneous connection, which may cause improper working issues.Note: Bluetooth headsets can also be replaced with Bluetooth helmets, intercoms, Bluetooth speakers, etc.
So on my bike
iPhone Bluetooth + Wifi is connected to the Carpuride.....
iPhone bluetooth connected to helmet headset....This way the sound is directly from the iPhone to the helmet, the Carpuride is just being used as a display and control unit.
You can turn the Carpuride off and music will continue to play, if I want it to pause I can select that on the Carpuride or
I just press pause on my helmet headset.I this this method stops a lot of issues with three elements, iPhone > Carpuride > Helmet all getting a connection at the same time.
So
Iphone > Capuride
Iphone > HelmetAlso using this method you can use "Hey Siri" to change music answer phone etc...
Edit - Sorry I don't know why the forum is adding so much space between the text.
This makes it easy
So on my bike
So
Iphone > Capuride
Iphone > Helmet
Quote from Sandrin on 28.08.2025, 16:17Quote from Guido on 16.07.2025, 09:21When Scenic is active on CarPlay it is normal that the iPhone screen says “Scenic active on CarPlay”. Every app will do this differently, depending on how the app is developed.
Hi Guido, first if all you are doing a great job!
I am using scenic on a CarPlay system and should be perfect to have the possibility to modify the route on your phone (is easy and quickest than the carplay device).
Quote from Guido on 28.08.2025, 16:24If you mean by modifying deleting, removing and adding via points, then this is not possible. The user interaction with the screen is very limited (by Apple) for safety reason. If you would like to change your routing mode (from fast to short or curvy, etc) then this will be possible from the next app update.
