CarPlay
Quote from waggy on 06.08.2026, 03:39Hi,
this is my first post, so Hi!!
I am looking at buying a Carpuride 702 for my bike to use with my iPhone 14. My phone would be in my pocket. I would be using Scenic and Spotify, can any one advise on battery life please, and with my phone in a pocket does the NAV side still work ok? I use a dedicated sat nav at the moment and it’s becoming a bit annoying using it’s features and trying to create routes
Cheers, hope you can assist!
Quote from Guido on 06.08.2026, 04:01In my experience, with my iPhone 16 plus + Carpuride, when not connected to a charger, I was able to ride a few hours (maybe 4 or 5) without charging. Maybe you could stretch that to a full day if charging during lunch in a restaurant or something.
But note that your iPhone 14 has a smaller battery, and battery will have lost some of its capacity over the years.
Make sure you have offline maps installed and download your music. It will make a big difference if Scenic and Spotify won’t have to connect to the internet for maps / downloading music, respectively.
If not already seen, here is my Carpuride review: https://scenic.app/carpuride-w702-review-the-easiest-way-to-get-carplay-on-your-bike/
Quote from pe112 on 06.08.2026, 04:16Hi waggy,
welcome to Scenic and to this forum!
I am using a similar setup: iPhone 13 and Carpuride W702.
Navigation works generally well with the iPhone in my pocket.
Only rarely the navigation freezes on the CarPlay display (speedo shows 0 then). Switching to a different app in Carplay for some seconds usually fixes that. AFAIK this has been reported to Guido already.Battery life is quite good as soon as the iPhone in your pocket is locked with the screen off. Six to eight hours of riding. A power bank in the pocket does not hurt for longer riding days.
As soon as you start thinking about mounting a button unit on the handlebar to control Scenic remotely (e.g. MotiveMonkey) it gets a bit different. Then you need to keep the iPhone unlocked in your pocket which means the screen will be on. This will make you loose maybe a third of your battery life, even with the screen dimmed down completely.
On the battery impact of Spotify I cannot comment because I do not use it.
These links might be of interest to you:
https://scenic.app/help/handlebar-controllers/?seq_no=2
Best, Martin
Hi waggy,
Carpuride W702 Review: The Easiest Way to Get CarPlay on Your Bike?
Best, Martin
Quote from waggy on 06.08.2026, 11:52Hi Both,
Thanks for your help, would you recommend the 702 or the 502, I’m not sure if the 702 would look too big on the old R1200GS Adventure
Hi Both,
Quote from Guido on 06.08.2026, 11:55I'd definitely go for the 702. Yes, it's a bit big (a bit bigger than the Tuareg display), but it doesn't look too big imo, and the big screen makes all the difference. Check my review... there is a link to a video too which should give you a good idea.
If you're unsure how it would look on your GS, maybe an idea is to cut out some cardboard in the 2 sizes and hold it where you'd like to put the Carpuride 🙂
Quote from Middelfrangge on 08.08.2026, 03:09Hi Waggy,
I started with a 502 and changed relatively quick to the 702. I used the 702 on my R1200GS K25 and now a 702 BS on my R1250GS and its for me perfect. I always have the phone either on my Quadlock adaptor or in my tankbag connected to USB. It works just with the battery but in about 4 hrs my Iphone 15 gets empty.
I do have in addition a Navcom Pro controller connected to use zoom and pan functions.
Which 1200GS do you have? a K50 or K25 (water or air cooled) I can provide a picture for both with carpuride 702 and Navcomm Pro controller.
edit: here is the link which I posted for the Navcomm Pro controller which shows a 702 on a K25. https://scenic.app/wp-content/uploads/IMG_2533.mov
Thomas
Hi Waggy,
Thomas
