Bug: Playgrounds can‘t change color
It seems like playgrounds are always in a bright green and the color can‘t be changed and they also can‘t be disabled in custom map themes.
You're right. That's a bug. It should be under the Areas > Land > Man-made section, but it's not.
Will add to the list. Might take a while as I have higher priorities at the moment.
