Bug: Coordinates format (Android Beta)
Quote from Asphalt on 31.05.2026, 05:49You may know this bug already... It seems Scenic iPhone is giving right formats, but Android Beta is not.
Scenic Android Beta is giving coordinates in the format:
DMS: degrees°minutes'seconds" E degrees°minutes'seconds" W
It shows both East and West in the same DMS string. It won't work. Instead, the first part should be N or S, and the second part should be W or E. E.g. in my location in Europe, the correct format is:
degrees°minutes'seconds" N degrees°minutes'seconds" EI would also make some changes to DEC-coordinates. Then it would straight work for example in Google Maps. Now it is such:
DEC: degrees,decimals,degrees,decimals (all commas)
The right string would be with dots and commas the following way:
degrees.decimals,degrees.decimals (degrees and decimaals are separated by dots and two parts by comma)
Quote from Guido on 01.06.2026, 10:02Thanks. I'll add it to the bug list for Android.
Quote from DRTBYK on 01.06.2026, 10:42I guess this is fixed in the internal-beta because they show up correctly in my version v3.66.
