Brand new to Scenic.
Quote from Luciferburn on 14.10.2024, 06:59Is there a full tutorial for using Scenic on MacBook?
I find it for iPhone but not for MacBook. (Very frustrated.)
Thanks newbie
Thanks newbie
Quote from BMWMark on 14.10.2024, 08:21Quote from Luciferburn on 14.10.2024, 06:59Is there a full tutorial for using Scenic on MacBook?
Thanks newbie
If you have a newer Apple Silicon Mac you should be able to run Scenic on your Mac as an App. Works pretty well for the most part to allow for larger screen. I've run it with no issues. If Mac has an older Intel chip don't think it will work. Just go to App Store and if it will run it should install.
Thanks newbie
Quote from Luciferburn on 14.10.2024, 08:24It works and runs on my computer. I keep getting the message " Route calculation error. No path could be found for input".
Guess I'm not using it right 🙁
Quote from Guido on 14.10.2024, 09:56
Could be a map error. Try moving you start point to a bigger road.
You can report map error like this: https://scenic.app/help/reporting-map-errors/
