Forum breadcrumbs - You are here:Scenic ForumAll things GPSBMW NAVIGATOR 6
BMW NAVIGATOR 6
Is it possible to route plan in Scenic and upload the route/file into the BMW Navigator 6 GPS?
If yes, can it be done wireless or do I need to use a cable?
I find Scenic a better system for route planning as compared to Garmin. But BMW being BMW, an easy solution is not always available.
Hi @fortunebayson,
I'm not very familiar with the BMW Navigator. Do you know if it has a way to import GPX files wirelessly?
With the Garmin XT this is possible using the Garmin Drive app. Have a look at this thread: https://scenic.app/forum/topic/creating-a-track-from-a-route-that-has-no-been-ridden-yet/#postid-3311
I'm not sure the BMW Navigators also work with the Garmin Drive app (as the BMW Navigators are basically rebranded Garmins).
To export a GPX file from a route, select the route from your route list, and then tap the 'export GPX'  button at the bottom. There are still some improvements to make (e.g. https://scenic.app/forum/topic/route-export-to-garmin-zumo-xt/), but these are already on the feature request list.
Hope this helps.
FortuneBaySon has reacted to this post.
FortuneBaySon
The BMW Nav 6 can’t do wireless import or use the Garmin Drive app.
However, using a USB cable you can put the GPX file in the GPX folder on the device. The device will then see the new file and ask you if you want to import it.
FortuneBaySon
Thank you both for the follow-up, much appreciated.
