Assembling rides
Quote from Al1 on 21.06.2020, 16:30Hi there,
I enjoy scenic for a lot of things, including recording my rides I enjoy to come back to it and to remember my trips. But sometimes, I stop recording the ride at the end of navigation a segment. Then start recording again, etc..
bottom line is that very often my days’s riding is actually split in 2 or more recorded rides. Thus the question: is there a way to concatenation 2 or more rides in a single one?
thanks a lot in advance
Cheers - Alain
Hi there,
Cheers - Alain
Quote from Guido on 21.06.2020, 16:34Hi Alain,
at the moment there is not, but it’s on the list to add that feature. I’ve had more requests for this.
Hi Alain,
Quote from Al1 on 21.06.2020, 16:37Guido, I appreciate the prompt reply.
Keep the good job, thanks for developing Such a great app!cheers - Alain
cheers - Alain
Quote from fxstein on 05.04.2021, 11:50Same here. Happens a lot, especially since the navigation options within a ride a more limited.
So at times i pull over, exit the ride, go into route planning to select where to head next with the routing options I like for the next segment.
Might also be an option to let me continue a previously started ride.
Quote from rnadeau on 26.04.2021, 11:19I have seen you can use Overview to search for and add a location even after a planned ride has completed. My suggestion is that, during a pause in riding, the user could visit the overview tab, and then be able to select either a new ride or an imported .gpx file, all the while continuing ride tracking, resulting in a single ride.
Quote from AstridM on 30.05.2021, 17:27Quote from Guido on June 21, 2020, 16:34Hi Alain,
I really appreciate your work, product and support. Thanks a lot for that. I’m also looking forward to v3 (no rush) and just wonder if the track merge feature is still on your to-do list? For sure it would improve my workflow and would allow me to mange all my rides in one tool only.
my best, Astrid
my best, Astrid
Quote from Guido on 30.05.2021, 17:30Hi Astrid,
itnis on the list but won’t be in there from the beginning. I want to get Acenic 3 out there ASAP so it will mostly contains same functionality as Scenic 2 with a few quick wins and obviously the biggest change… the new maps.
cheers,
Hi Astrid,
cheers,
Quote from AstridM on 03.06.2022, 02:15Hi Guido,
I hope this finds you well. I just wanted to do a quick check-in, to learn if you found the time to think about the track merging functionality. Alteratively an option to simply have all rides of a given day in one track, would also be great.
Other than that, me and several friends really like Scenic. Thanks a lot for your great work.
Astrid
Astrid
Quote from Guido on 03.06.2022, 06:55Hi Astrid,
Sorry. Did not have time for this yet, and will be a while longer I’m afraid.
There is a workaround though: https://scenic.app/forum/topic/combining-multiple-scenic-tracks/#postid-3516
Hi Astrid,
